Quick FEL question - Teeth or no teeth?
   / Quick FEL question - Teeth or no teeth? #1
jct-mo
Missouri
Mahindra 2816
And how much are they to be added to the bucket? Never had a loader before, so all opinions appreciated.
JT
   / Quick FEL question - Teeth or no teeth? #2
I considered teeth as well but was advised against it on a small tractor. I was told that it encouraged doing a bit too much for the tractor to handle. I'm not sure whether that is correct or not, but I figured I could add the teeth later if I found that I really needed them. I haven't had my tractor long enough yet to see if I really need teeth, but it's done all I've asked it to do.
   / Quick FEL question - Teeth or no teeth? #3
If you unerstand your tractors limitations I would consider them almost as important as the loader itself. It boggles my mind how effective they are for digging.
Just tonight I was diggin out back and had to "pop" some sandstone out. I used a tooth to get under the rocks and slowly curled while backing out and they came out with no problem.
Another advantage is that when carrying logs or anything wider than the bucket you can use the teeth for the item to rest on. Since the teeth stick out past the edges of the bucket you can wider items on there, just roll the bucket back.
   / Quick FEL question - Teeth or no teeth? #4
I consider that my bolt on tooth bar increased the usefulness and capability of my FEL bucket by at least 100%.
A toothbar, IMHO, is one of the single most cost effective items available for a tractor, once it has a FEL/bucket.
Reasons:
larger load
hang chains on teeth, pick up stuff
keep edge straight
dig MUCH easier into a pile of material
put teeth under stuff, chain it to bucket, lift and go, reduces sliding off
lots of other uses...
Thanks for the input guys. Any idea what a dealer will typically charge on a new tractor purchase to add the tooth bar?
   / Quick FEL question - Teeth or no teeth? #6
jct-mo:
Welcome to TBN :D! You should consider a bolt on toothbar for your bucket. Drill two holes in the bucket's sidewalls and you are ready to mount the toothbar. Easy on-easy off. A toothbar really improves the digging efficiency of the FEL. There are several after market toothbar manufacturers out there. Markham appears very popular here at TBN. Jay
   / Quick FEL question - Teeth or no teeth? #7
quote
"A toothbar, IMHO, is one of the single most cost effective items available for a tractor, once it has a FEL/bucket."
Is absolutely true. You'd be crazy not to get a bolt on tooth bar. Great bang for the buck.
To my mind, Tractors should be sold with FELs and toothbars - the option should be to have them removed. They add so much to the utility of the tractor its like an entirely different machine. I think most people would be nuts not to get them.
   / Quick FEL question - Teeth or no teeth? #8
Cost of toothbar varies by size and weight (pounds).. ballpark is $350...
You can install yourself if you are tool handy. Numerous posts on TBN discuss how people did it, with photos. This is a good opportunity for you to try the TBN search engine.
Drill holes in side of bucket, insert bolts, tighten. Hopefully you could see one installed...easy to understand once you see it. My John Deer toothbar is probably the heaviest I have heard about... 136lbs ... I had to use some washers as shims to close the .5 inch gap between the toothbar tabs and the bucket sides.
Get one, you won't be sorry.
Again folks, thanks for the advice. I've taken it. I am handy with tools, but unfortunately short on time, so had the dealer install the tooth bar. They are delivering the tractor tomorrow. I am so glad to be getting rid of the old AC, and getting something where everything will work. There are so many tasks that have been put off because I didn't have the loader, I'll even have less time. :) I'll get some pics posted as soon as I can.
Well folks, got the tractor delivered. Don't want to get it muddy, but know that will happen soon enough. Here's a couple of pictures. Really like it, and glad to be rid of the old beast.
   / Quick FEL question - Teeth or no teeth? #11
Nice tractor! I'm sure you're going to love it.
   / Quick FEL question - Teeth or no teeth? #12
JCT-MO
nice clean tractor, but it will get dirty.
i am impressed with that joystick, and you can
get on the tractor from the right side. my tractor,
L3000DT, you cannot mount the right side, because
the joystick is in the way.
what part of missouri?
accordionman
wlbrown
wright city, mo.
   / Quick FEL question - Teeth or no teeth? #13
try the bucket with and without the toothbar and report back :D I think you'll feel good about the money spent.
   / Quick FEL question - Teeth or no teeth? #14
get a couple of spare bolts & nuts for that toothbar and put 'em in your toolbox. After having to hammer mine out a few times I stripped the threads and was out of business til I could get to town to buy new ones. I have grade 8 ones in there now and a spare set in my box in case.
   / Quick FEL question - Teeth or no teeth? #15
I have been told that the teeth make digging 100% more efficient, good investment. I meant to get some on mine, but concentrating on a box blade now. A guy I know who does site work says a box blade is the second most useful accessory for a tractor after a FEL. Have fun on that tractor! A guy I know said he had heard only good things about Mahindra tractors when I was looking to buy, but I am a Harley-Davidson, John Deere, Chrysler, Budweiser guy (American branded, if not made).
   / Quick FEL question - Teeth or no teeth? #16
Where is your television set made? I recently watched an RCA, made in U.S.A.. It was at the county landfill waiting to be recycled.
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
2016 Deere 180G (A60462)
2016 Deere 180G...
3015 (A56857)
3015 (A56857)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
2020 CAT 308 (A53317)
UNUSED RAYTREE RMRB72-72" HYD POWER RAKE BUCKET (A60432)
UNUSED RAYTREE...
