Quick disconnect, my ***
/ Quick disconnect, my *** #1
canoetrpr
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
I've had my hydraulic top link off the tractor for a couple weeks now as I've been working on harrowing - harrow hooks up to draw bar. \
I have connected and disconnected the hydraulic top link to the remotes at least two dozen times with no trouble at all. I have the Parker Pioneer QDs.
Today I go to put the HTL on and for the life of me, I cannot get either of the hoses to hook into the QDs????. The male end would go in as far as it normally takes for the spring jacket on the female end to normally pop back and lock it in place.... this time - no go! I pushed and pushed and screwed around with them for about 40 min - finally gave up.
I decided that the male ends were the problem as I could hook in my side link hoses into the female QDs for the top link spool no problem.
I had two new male ends spare so I replaced the ones on the hoses and voila! they now fit in.
I don't quite understand this. I've done this about two dozen times with no problem. I sure as heck don't think that they should wear out from connecting, disconnecting a couple dozen times.
How do the rest of you deal with stubborn QDs? Is there some secret Parker mantra that I should be chanting before trying to connect these up?
I've decided to rig up a piece of chain to the OEM top link holder so that I can hold the HTL while I am not using it, without needing to take it off..... sorta defeats the purpose of having QDs though.
P.S. - As if to shame me, after I had taken the old male ends off, I tried hooking them up to another spool that I have never used and they went in right away!!!! No clue what the heck is going on here.
/ Quick disconnect, my *** #2
My guess is the hydraulic top-link was pressurized. I've had that problem with my front-end loader. I forgot to de-pressurize before I disconnected one time, and had a heck of a time getting it reconnected. Finally had to manually "vent" the FEL male disconnects by pressing (quite hard) on the nipple on the end. Then it went right in.
That's just my guess. Could be wrong.
Chet.
/ Quick disconnect, my *** #3
Sometimes you have to break a line loose to bleed the pressure.
The nipple push works good, unless it has too much pressure on it.
BTI
Hmm... I suppose this explains why the same male disconnects seem to work fine now :eek:
So I guess to de-pressurise it, I should simply turn off the tractor and move the remote lever in all positions - like I do for my FEL? DOH!
I'll bet the last time I took the HTL off while the tractor was on and didn't think to depressurize.
I'll put those male disconnects away for another day .... they seem to work just fine now that they are off.
/ Quick disconnect, my *** #5
Also de-pressurize the line before trying to push them on. Push the ball against something to release pressure, just sitting in the sun could pressurize the lines enough to be an issue.
/ Quick disconnect, my *** #6
I think someone on this site showed how they use a copper pipe cap to cover the male end, then rap it witha hammer. I use a thick rag to cover the end and tap the ball with the handle of the hammer to release the pressure.
/ Quick disconnect, my *** #7
I agree with Chetlenox. The same thing has happened to me.
/ Quick disconnect, my *** #8
Even still, if the ambient tempurature changed since you disconnected the HTL, the fluid may still expand and make you take the pressure out of the lines on the HTL.
One way or the other, I'll find a way to depressurise the HTL. Never thought about the fact that those lines might be under pressure. Makes sense....just didn't figure it out :eek:.
Next time I'll put something over it and hit it with a hammer or something.
/ Quick disconnect, my *** #10
It happened to me on the FEL once when I was in too much of a hurry. I used a wooden dowel and tapped it with a hammer. It shot hydraulic fluid all over the place so be careful, wear eye protection.
/ Quick disconnect, my *** #11
Had to release the pressure on my loader to hook it up the other day. It had been off a few weeks and had settled some. I used a socket extension and a hammer.
/ Quick disconnect, my *** #12
I release pressure by putting a clean paper towel into the bottom of a bucket and pressing down. Towel keeps end clean and bucket keeps fluid captive and out of face.
Mike
/ Quick disconnect, my *** #13
I have the same problem as you.
What I do to release the pressure is attemp to hook up one of the QD's first. If it goes on, great...if not, I touch the valve handle to pressurize the other QD. Then the one I'm trying to put on has depressurized. You will have to see which way to bump the valve handle for each QD on your machine. Then I bump the valve handle the other way and it pressurizes the QD I just put on and depressurizes the other and I can push it in and lock it.
One other thing I noticed.
Sometimes the diameter of the male QD gets a little banged up. I run a file or some wet and dry sand paper over the male ends to get rid of any burrs or dings. They are fairly close fits. This does not hurt the seal since the seal is an "O" ring of some sort and not the OD of the male QD. It also does not hurt the spring loaded ball retaining method, since those balls ride in the groove on the OD of the male QD. I found doing this lets then enter and exit easier.
/ Quick disconnect, my *** #14
I also use a socket extension. Blunt enough not to do any damage. Beefy enough to depress the nipple. Never had to use a hammer. Just a good brisk tap. Can get a little messy so keep a rag handy.
/ Quick disconnect, my *** #15
on our jaws of life in the fire truck, we always hook the hoses back to each other. That way the pressure is equalized. I always push the actuator both ways before unhooking but I dont know if it is nesacary or not. maybe a jumper hose with a male on one end--female on the other?
/ Quick disconnect, my *** #16
also, be very careful when bleedig system, had a guy squirt me in the eye with the orriginal hurst fluid, it was made out of some nasty stuff that REALY hurt in my eye.
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
2006 Bentley Continental Passenger Car, VIN # SCBBR53W76C033311 (A65563)
2006 Bentley...
Lot of (15) Hedge / Black Locust Posts (A66408)
Lot of (15) Hedge...
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
White 18' Disc Harrow (A66408)
White 18' Disc...
8ft 3in Teakwood Live Edge Slab Table (A65583)
8ft 3in Teakwood...
