Quick Attach Plate Allignment
/ Quick Attach Plate Allignment #1
Greenland South
NE British Columbia
New Holland TC45DA
What I have is a New Holland TC45DA.
I'm looking for some info on adjusting the bucket cylinders so they have the same throw. Currently there is a 3/8" difference between the exposed rams. This is translating to the quick attach plates being about an inch out of alignment.
As you can imagine changing my bucket to the grapple is no longer a "quick" operation. I have to use a come along to suck the bucket or grapple into the mounting plate in order to lock it in.
I have tried bleeding the ram with the longest throw, but I know very little about how hydraulics work. My service/repair manual doesn't appear to address this problem.
Paul.
/ Quick Attach Plate Allignment #2
If those cyl came as matched set, the rod length should be the same.
Are you sure the bucket is not warped.
/ Quick Attach Plate Allignment #3
You bent something. Is it off the same amount on bucket/grapple? If so, you tweaked the mounting plate. Pictures?
/ Quick Attach Plate Allignment #4
My pops bent the attachment point on the NH L185, twice. I have since repaired it, twice. He would have to pick up the attachment and push the “bent” side against a tree in order to mount it/latch it. The frame had twisted. This happened because one of the QA levers was bumped up by brush and he didn’t catch it quick enough before trying to rip another cedar out of the ground.
Take measurements on your machines attachment points. Good luck.
Thanks for the links. Went out and had a good look and I have indeed bent the torque tube. Looks like an easy fix.
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
2008 CATERPILLAR 242B2 SKID STEER (A65053)
2008 CATERPILLAR...
2022 EZ-GO ELITE...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
Rake Master CR-50SG-LD (A64126)
Rake Master...
