Quick Attach Plate Allignment
/ Quick Attach Plate Allignment #1
Greenland South
NE British Columbia
New Holland TC45DA
What I have is a New Holland TC45DA.
I'm looking for some info on adjusting the bucket cylinders so they have the same throw. Currently there is a 3/8" difference between the exposed rams. This is translating to the quick attach plates being about an inch out of alignment.
As you can imagine changing my bucket to the grapple is no longer a "quick" operation. I have to use a come along to suck the bucket or grapple into the mounting plate in order to lock it in.
I have tried bleeding the ram with the longest throw, but I know very little about how hydraulics work. My service/repair manual doesn't appear to address this problem.
Paul.
/ Quick Attach Plate Allignment #2
If those cyl came as matched set, the rod length should be the same.
Are you sure the bucket is not warped.
/ Quick Attach Plate Allignment #3
You bent something. Is it off the same amount on bucket/grapple? If so, you tweaked the mounting plate. Pictures?
/ Quick Attach Plate Allignment #4
My pops bent the attachment point on the NH L185, twice. I have since repaired it, twice. He would have to pick up the attachment and push the “bent” side against a tree in order to mount it/latch it. The frame had twisted. This happened because one of the QA levers was bumped up by brush and he didn’t catch it quick enough before trying to rip another cedar out of the ground.
Take measurements on your machines attachment points. Good luck.
Thanks for the links. Went out and had a good look and I have indeed bent the torque tube. Looks like an easy fix.
iDrive TDS-2010H...
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
2015 Toro Sand Pro 5040 Bunker Rake (A59228)
2015 Toro Sand Pro...
2025 JMR Tree Boom Mini Skid Steer Attachment (A59228)
2025 JMR Tree Boom...
2025 72in. Hydraulic Dual Cylinder Rock Grapple Skid Steer Attachment (A59228)
2025 72in...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
