Quick Attach Forces Questions
/ Quick Attach Forces Questions
These are the concepts I was trying to get at.
I don't like the pins only going in a little bit. What would be better (in my mind) is if there were some 1" holes aligned in both the FEL plates & quick attach plate so that when coupled, you could slide in some big bolts to help keep the attaching attached.
Thanks again!
/ Quick Attach Forces Questions #12
Wanting to build something similar to this?
/ Quick Attach Forces Questions #13
Thanks again!
What you are desiring is the Euro style quick attach. John Deere has used this type for years as well as others. Solid attachment with no worries about it separating regardless of stress angle. Here's a Google link to a bunch of pics.
european quick attach - Google Search
/ Quick Attach Forces Questions #14
Looking at Bryan's pic and/or mine below you can see that we don't put stress on the lower pins. By keeping the FEL QA plate in a vertical situation the load is always carried by the top angle brackets. Bryan's is an excellent example of a properly built boom pole designed to apply the stress properly on the Quick Attach.
To see how inefficient the SSQA is with the mounting plate in a horizontal position raise your Bucket until you can easily see it from the tractor seat. Then dump the bucket as far as it will go. Then jiggle the curl function and watch the bucket. You'll see it "slopping" in the brackets. It's not designed to carry load in that position. I've read horror stories here on TBN of operators putting stress on their attachments in that position and having them come unhooked. I'm very conscious of this when using my Grapple.
/ Quick Attach Forces Questions #15
I have Quick Attach on my tractor. On any of the implements... the Quick Attach plate basically consists of the overhang on top and some holes on the bottom and the mateplate at the back. The FEL plates tuck under the overhang and the Quick Attach pins go down in the holes which pushes the FEL plates against the mateplate.
The overhang steel seems substantial (steel all across the top keeping the FEL plate edge from popping out). But the pin tips going down in the holes only go down a little bit... (I haven't measured but it looks like 1/2 to 3/4 of an inch).
(Seems to me that a for a better connection, the pins should go deeper into the holes? (Why don't they go deeper?)) Because they are spring loaded to go as deep as possible, compensating for manufacturing tolerances and wear in the slots.
Here's my theoretical question:
What if I took a blank quick attach plate (made of 1/2" steel) and welded a 15' long - 4"x4" square steel pipe (parallel) to the flat face of the quick attach.
When considering the quick attach plate connected to the tractor FEL... when the quick attach plate is vertical, the pipe stands up like a flagpole. But when the quick attach plate is horizontal, the pipe is horizontal to the ground. When the pipe is vertical, the forces on the quick attach connection seem workable. But when the pipe is horizontal, it seems the forces would threaten the connection making the pin tips or something fail. If there was weight out on the end of the pipe, it would seem the failure threat would be much greater.
Any idea how much weight would be required to make the connection fail? For example, if I put 300lb basket on the end of the pole, when the pole is vertical - no problem. But when the pole is horizontal, would 300lbs added to the end make the connection fail?
Thanks for any ideas!
Here is a visual of your theoretical question with a 24' cedar:
The SSQA plate is still tight. :thumbsup:
This is a light weight pallet fork frame that came off of the SSQA, when I tried to lift too much weight:
If there is too much gap at the bottom, the plate can slide up when back dragging and come off of the top of the SSQA, usually on one side, twisting the cross tube.
/ Quick Attach Forces Questions #16
Back dragging or picking up the weight of the machine with the bucket/forks front edge put's the most "work" on those lower pins. I have bent the top edge like in xfaxman's pic on some, I'll repair by cutting out the (unnecessary) middle, straighten out the sides and weld in a new support about 12" in from the side's just enough to clear the machine side contact points. This cut's the span between support way down.
Thanks very much to all for the great pics and explanations!!
Those pics basically show the pole welded perpindicular to the quick attach plate... like this:
I will be welding the pole to the quick attach plate in parallel with the plate... like this:
__ (*sorry, I tried to make this quick attach plate line over on the right side of the pole)
---------- (this is what it would look like with with pole on the ground before attaching tractor to the quick attach plate.
When the quick attach plate is rotated and the pole is raised up, it would look like this:
|| (this would be the primary operating position and all weight would be pressing downward on the quick attach plate/FEL plate connection).
The idea I'm contemplating is basically a man-basket on top of the pole (don't worry about how the man get's into/out of the basket, that will be done safely with ladder, etc).
What I'm concerned about is the raising of the pole from ground position to upright position. The basket on the end of the pole weighs about 250-300 lbs without the man inside (not too much). But the length & weight of the pole influences the forces put on the connection during the raising. I was thinking about making the pole 12-15' long.
I know that when I try to lift/rotate the bucket with too heavy a load, the hydraulics will just bypass when it can't do it. I want to make sure that the tractor is capable of rotating/lifting the load into the upright position. I'm pretty sure the lifting is possible, but want to make sure the rotating is possible too before I build this thing.
I would use a 1/2" steel quick attach plate to reduce the possibility of bending the plate.
Thanks again!
/ Quick Attach Forces Questions #18
I recommend gussets or extra bracing so that the top lip can't bend when you are rotating the pole up to vertical.
Here are the gussets used on my stump bucket:
And the bracing on the bucket:
/ Quick Attach Forces Questions #19
If the curl cylinders won't lift it from horizontal, you could rest the cage on a sawhorse to give it an upwards push until the cylinders have better leverage. I have a 20' boom pole I used to use to pull well pumps. It would raise from horizontal, but it was working to do it at the start.
/ Quick Attach Forces Questions #20
Did I miss exactly what you want to make & do in this "structural" discussion?
I knew a guy that built pole buildings that welded a 4x4 (20') to a ssqa plate and he used it to set trusses. Being able to drive into a building (on dirt, no foundation) you don't need the "reach" of a crain. Once the truss & pole were close to vertical the 200# truss was virtually no load to the skid steer or pole and he was basically right under it.
I took his idea and embellished it a little.
2008 Mercury 25HP 3-Cylinder Boat Motor (A59231)
2008 Mercury 25HP...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2020 DRAGON ESP...
1990 Bayliner 19ft Trophy Center Console Boat w/ S/A 20ft Boat Trailer (A59231)
1990 Bayliner 19ft...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
2014 Toyota Tundra Single Cab Pickup Truck (A60352)
2014 Toyota Tundra...
