Loader Quick Attach for 67 Series Loader
/ Quick Attach for 67 Series Loader #1
Mike68
Granby CT
John Deere 750
Has anyone had any luck getting a quick attach mount that fit the 67 series loader arms? I have a JD 750 with the 67 series loader. I want to convert the pin on style bucket to QA so that I can make use accessories such as pallet forks and a snow blade easily.
As I understand it the centerline distance between the loader arms would be different than a standard QA equipped tractor. That should be OK as I would just compensate when I put the QA brackets on my bucket, etc. I just would not be able to borrow QA attachments.
I am more concerned if the QA mount would fit on the end of the loader arms(width) and if the pin diameter and spacing would be same.
/ Quick Attach for 67 Series Loader #3
I've got the same question about a quick attach for the 67 loader on my JD750.
Figured I'd give this thread a bump and see if there was any new info out there.
/ Quick Attach for 67 Series Loader #4
There is a manufacturer called HLA in Ontario. They build all kind of loader attachments and adapters.
/ Quick Attach for 67 Series Loader #5
Worksaver makes many QH adapters, but the main killer for the 67 will be adding the additional weight and moving the attachment out further. I'm thinking the #832655 plus the pin-on bracket they mention to adapt it, your looking at adding an additional 150 pounds though before you even add an implement.
Attachments Using Quick Attach System
/ Quick Attach for 67 Series Loader #6
Thanks for the replies, folks!
@kennyd, really good point about the increased weight and the distance of it from the pivot - I hadn't thought about that. With that loader and small tractor, I'd guess that it would really limit the utility for the loader.
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2004 Chevrolet Silverado 1500 Pickup Truck (A61573)
2004 Chevrolet...
2009 CPS Manac SGH36 Hopper Bottom (A64047)
2009 CPS Manac...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63118)
2021 Gehl RT215...
2020 KENWORTH T680 6X4 T/A  SLEEPER  TRUCK TRACTOR (A59910)
2020 KENWORTH T680...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
