Quick and Cheap Leak Fix
/ Quick and Cheap Leak Fix #1
One Acre Farm
MD
I have an old Farmall 140 that I use to culitivate on the farm and it has had a leaky seal since it was given to me. It is a slow drip from under the gear housing. To properly fix it, I am going to have to split the tractor, something I cannot do, nor afford at the moment. Any ideas about a good way to trap that oil so it doesn't leak on my plants as I cultivate?
/ Quick and Cheap Leak Fix #2
How much oil is there in it? I'd try changing it out. New oil often rejuvenates the seals. I've done this on several transmissions/differentials. Just change the oil, and leakage either stops or slows down a lot.
Ralph
I did try that, didn't slow it down though
/ Quick and Cheap Leak Fix #4
Lucas sells alot of different stuff that will probobly work pretty good . Where are you in MD ?
/ Quick and Cheap Leak Fix #5
They say that this stuff works. I have purchased it from this site and did use it on a hydraulic ram. It slowed the leak but did not totally stop it.
New Tech International
/ Quick and Cheap Leak Fix #6
Wonder what would happen if you put a few gallons of bar oil in it?? Not suggesting... if the oils would even mix.
I'm in montgomery county, and am interested in someone fixing the leak but not till the end of the season
/ Quick and Cheap Leak Fix #8
I would look at AT205 look it up on amazon.com. I would try this product before I tried anything else I discovered it from a guy on U tube that says that he has had great results it would be a cheap easy fix and would be worth the effort before trying anything else. just my 2cents.
/ Quick and Cheap Leak Fix #9
I havn't tried it but if this stuff will slow an hydrualic leak at that sort of pressure then you would think that a tranny case would be a walk in the park
/ Quick and Cheap Leak Fix #10
is it the seem of a sump that is leaking? if so, pressure wash then clean with carb cleaner then use a bead of jb quick weld on it.
soundguy
SCAN TO RECEIVE TEXT UPDATES (A63291)
SCAN TO RECEIVE...
2005 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61573)
2005 Dodge Ram...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A64194)
Paladin 12in...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
Hurricane THB750 Hydraulic Breaker Excavator Attachment (A61572)
Hurricane THB750...
Kubota Diesel Engine - Pump Takeout (Skid Mounted) (A63689)
Kubota Diesel...
