Tires Questions before loading tires with water
/ Questions before loading tires with water #41
Hmmmmm.. I filled the rear tires on my JD2210 and it made a LOT of difference in stability on steep terrain. They are 26x12x12 tires. Added 45 lbs to each tire.
Standard SCUT / large lawn tractor sized tires, right? I added 10 gallons WW fluid and still had room, so I added almost a gallon of water to each of my tires. Water is 8.3 lbs / gallon. WW fluid wasn't quite as heavy as water, but even at 90% that's still 7 1/2 lbs / gallon. So I added at least 83 lbs to my tires. And yes, it makes a HUGE difference in stability. I think you might be able to fit some more in yet.
/ Questions before loading tires with water #42
I have had my rear tires filled with a water/methanol mix for the past 8 or 10 years. Works great and never a problem. The tires were filled by a local tire shop.
/ Questions before loading tires with water #43
Don't fill tires above the rim, about 75% full. A completely full tire has no air to compress & absorb shock. That means hitting a bump can easily blow the tire off the rim.
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
Case 1845C Skidsteer Loader (A66285)
Case 1845C...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
Murray Explorer Go Cart (A65640)
Murray Explorer Go...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
