Questions about the PowerTrac 425
   / Questions about the PowerTrac 425 #41
Question: Do you think the Homeowner 422 PT would be enough? Is there a big difference in power/capability between the 422 and the 425 (besides the obvious 3 HP)? Seems like one major difference is the 425 has rear hydraulics for a backhoe, but we don't actually plan to get that, so why pay for the hydraulics?
I have a PT422. If I did it all over again, I would buy a PT425. Well worth the extra $3k or so.
Why:
1. Double steering rams on PT425. PT422 has a single steering ram, which has caused problems for some owners (ripped the fork supporting one end of the ram out of the bottom of the tractor. Repairable... as anything made out of 1/4" see is, but the PT425 design is better. The PT422 has the hydraulic cylinder underneath a false floor in the foot well, and that area fills up with grass and debris.
2. More power. My 22 HP engine is very challenged by brush hogging. I could do with some more power. One of these days I will be going for Kent/KMA's 28HP FI conversion. BTW, someone reported that PT would build you a PT425 with the Robin 28FI motor. Worth a try.
3. Higher from lift. Loading a truck is a challenge. A few more inches would make a big difference.
4. Higher torque wheel motors. Okay, I have never felt this is a problem on the PT422, but those with the more torquey motors like them.
The PT2425 is the model with the built in back hoe (rear hydraulics) Wouldn't want one because it looks like it has a higher center of gravity. If I had one, it would have been on its side more than once by now. Isn't designed for any other attachments from that point, although someone could get creative.
Honest, front quick attach only isn't that much of a liability when you get used to it. This thing is very maneuverable.
   / Questions about the PowerTrac 425 #42
As i see it you may want to look at the new Steiner 440 will mow on steep hills and has a good number of front mounted attachments up to 40 HP. and it has the optional cat.1 3 point hitch. You can pull what you want?? jim
She wants to do ditching and road maintenance. The front end loader offered by Steiner for the 440 is borderline worthless. It's maximum lift capacity is only 365#, and its recommended transfer weight is only 200#. It weighs over 700# and you have to hook it up to the front PTO as it has its own hydraulic pump. Don't get me wrong. I'm a big fan of the Steiner tractors. But they are more for grounds maintenance of established grounds than construction of new grounds, and that's what the OP seems to be wanting to do. That, along with road building/maintenance and ditching makes the Steiner the wrong machine for those tasks.
A Power Trac with a mini hoe would make quick work of ditches. However, box blading would be my biggest concern. I'll leave that to the folks with box blades, as I don't have one. I know my PT425 does not have the traction or weight to bust up really hard, hard soil or packed clay between rocks.
   / Questions about the PowerTrac 425 #43
I have used a box blade with my tractor and it does not function as well as with a regular tractor. Given the weight etc of my tractor vs the smaller PT's, I would have to believe they perform less well.
Ken
   / Questions about the PowerTrac 425 #44
Very True Ken. I have not really tried my Box Blade much on a hard surface, mainly use it to level things out, and does a ok job at that. Takes a lot less time then back dragging with a blade, and does a better job of making the surface even and filling in holes.
Ken
   / Questions about the PowerTrac 425 #45
I used to rehab baseball diamonds at Little Leagues and churches with our PT425. We had some fields with packed clay and some with moon dust (granulated limestone). If it was dry, I had a heck of a time breaking the surface with our small bucket with teeth. The PT front would just lift off the ground. Only 750 pounds to push down with really. I have a single plow share that I mount on a quick attach plate. That concentrates the load on one point instead of the many teeth and I still couldn't break through the stuff. The only way I could break it was to get it at an edge and try to get under it. And even then, many times it would just stop the tractor and spin the tires. That's why I'm hesitant to purchase a box blade for our PT425. I'd like to see one in action.
   / Questions about the PowerTrac 425 #46
MR, where did you get that weight for the front bucket? I can pick up a full 48" bucket of modified with no effort. and to maintain a road with a crown and a ditch i would use a back blade. Nobody would use a mini hoe to hold a grade for along a road. I had a PT and it doesn't have the power or traction to pull category 1 3 point hitch implements. Nor will the PT. mow on hills with the new 440, and you don't need the weights like the old steiners or ventrac a 72" calls for 2 weights half what it use to and with their weight transfer system, you change it on the move. The only thing the PT has is hydraulic lifting power, but it suffers from lack of travel power. They all have their place, steep hills and mowing and 3 point hitch implements are not on the same page with Power trac.
   / Questions about the PowerTrac 425 #47
I think the numbers you had on there were for the 430 and the stupid loader front. They have no numbers on the 440 as of this time but i did use my little slip scoop and picked up a heaped bucket of modified stone and that would be 5 + cubic ft. with no problem. Modified weighs 3000 to the cubic yd. so that would be 500 +lbs. in the bucket. Granted a PT will pick up more, but that is where it stops……...
   / Questions about the PowerTrac 425 #48
I think the numbers you had on there were for the 430 and the stupid loader front. They have no numbers on the 440 as of this time but i did use my little slip scoop and picked up a heaped bucket of modified stone and that would be 5 + cubic ft. with no problem. Modified weighs 3000 to the cubic yd. so that would be 500 +lbs. in the bucket. Granted a PT will pick up more, but that is where it stops?...
I got that information from the Steiner website, while looking at the 440 specs, and clicking on the attachments. Its a pop out so I can't get a link to the URL, but you can go to this page, scroll down to the loader and click the 'read more' button and there it is. Steiner Tractors Attachments | Steiner Tractors
I wasn't suggesting using a mini-hoe to crown a road. I was suggesting using a mini-hoe to scoop ditches, similar to how they make ditches with a gradall around here. You can't excavate below grade with a Steiner slip scoop. I don't know if you can with their FEL, but with only 365# of lift, I doubt it has much break out force. You can with a mini-hoe, and for that matter, you can excavate below grade with a bucket on a PT as well. It scoops out real nice ditches below grade.
I know the PT400 series doesn't have pulling capacity and I believe I mentioned that a couple times, and passed on how well it would do with a box blade because I just don't know. I'd have to see one running a box blade in person before I'd consider purchasing a box blade.
   / Questions about the PowerTrac 425 #49
MR, If you look at the each attachment, it will have what tractor it is used with. I'm glad you told me you you can't dig below grade with a slip scoop……. i will quit doing it. I maintain my driveway with the slip scoop, granted it isn't the greatest but it does the job, and it will dig ditches, haul top soil and stone when needed. The Steiner will cut grass better than anything i ever had including a Ferris zero turn,Ventrac and the PT…….
I had a box blade on the PT but it worked but a bit much for it. i would try to find a light weight one. Nothing more than 4' and it should do ok just weld a quick attach plate on it. i also used a york rake i attached the same way that does a fine job also……… jim
   / Questions about the PowerTrac 425 #50
I understand totally the issue with "just" hiring folks. Not easy here either.
I don't know if this helps, but I use my FEL to maintain ditches, the way jfisher's shows, by using the PT crossways to the road. I can scrape a little material up to make a lip, or pull it into the ditch to take a big gulp and clean it out. Your road has to be wide enough, though.
Driving backwards is something that I've gotten used to. If I road maintenance turns into a big deal, I would look for an old D1/D2, park it out back and use it whenever you need it. If you do it well, and the road has enough material on it, you won't do it very often... Having a really heavy piece of equipment scrape roads is great; you get to pack the road with the dozer weight, and can get more down force on the blade.
I looked at the Steiner and the ToolCat, and for me, they don't have the lift and functionality, but much of the decision is very local. If almost all you do is mow, the Steiner is a great machine. If you need to much work with an FEL, there are, in my opinion, better options. Personally, I needed an all around tool that would absolutely function safely on slopes.
In the US, for slope work, there aren't a great number of choices. You have the PT, Aebi from Switzerland, and the AntonioCarrero if you don't have to go sideways on a hill (look at their slope specification closely, it is 5" narrower that the 1445, and much taller).
When in Rome... You need to figure out what you need, and buy the right tractor for you. You are the end user and it needs to be right for you. I think that if you visit Tazewell, you will get a sense for what it can do.
As a general purpose tool, I think these are really, really effective machines. If you have a specialized need, there may be better choices.
Have fun!
All the best,
Peter
Thanks for the invite. That's very kind. Would like to see a picture of the rake. Does it allow you to maintain your road driving FORWARD?
"Hiring someone" sounds easy but isn't around here. We have one traffic light in the entire county, no McDonalds, no Walmart, no hospital or other medical facility. In short, sparsely populated with very few businesses. The few good contractors are booked year-round (took us 2 years to get the electrician to come out). The companies from nearby cities always say they never go "all the way out there." It's the price you pay for living in the boonies. I could tell you stories of attempting to get workers--the yahoos who don't know what they're doing, the scary ones with ******** tattoos or who are on drugs--but I won't. So yeah, "hire someone" is a good solution....in theory.
This is one reason for buying some kind of tractor; to be less dependent on hiring this stuff out.
I'm pretty disappointed the PT can't pull any rear attachments. Seems like a major missing feature. And I can't see driving a box blade BACKWARDS up our roads, with a ditch on one side and a steep drop-off on the other. Have realized tractors aren't really designed for rough steep property like ours. Will have to think about this some more.
It's obvious that anything will be a compromise. Just have to figure out what makes sense.
Bell 1600 Gallon Nurse Trailer (A56438)
Bell 1600 Gallon...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2012 TAKEUCHI TL12 SKID STEER (A60429)
2012 TAKEUCHI TL12...
Deere 35P (A53317)
Deere 35P (A53317)
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
