Questions about snow removal.
/ Questions about snow removal. #21
I looked up the specs thatJD appears to be a construction type machine with a serious back hoe and end loader. I doubt it has a removable backhoe. They usually don’t have SSQA but I’m sure one could be adapted but might take a lot of work.
/ Questions about snow removal. #22
I suspect a 100 HP, 14,000 lb. construction BH/loader would be a viable snow removal machine with just the bucket. Angle plows that attach to the bucket or in place of the bucket are available if the OP wants to plow more quickly. If snowbanks become a problem the loader should be able to push them back easily.
/ Questions about snow removal. #23
In the initial post, he mentions he got a new (to him?) tractor and mentions compact and utility tractor. In a another thread, he mentions he's looking for a Kubota MX5100 HST or 4400 HST so I don't think he'll be using the JD TLB for snow removal.
/ Questions about snow removal. #24
In the initial post (in this thread) he says he got a new tractor; in post #11 he said it was a JD 310L. In the initial post he asked what we (other forum members) used on our CUTs and UTs. The other threads date from 10 years ago, 2011. Also in post #11 he said he was tired of using his Gravely for snow removal, and he only lists the Gravely 16G and JD 310L in his profile.
It will be most interesting to find out after the Winter of 21-22 what he did and how it worked out for him.
/ Questions about snow removal. #25
I just took ownership of a tractor, and hope to use it to plow two driveways. I'd like to ask some questions.
1. What do you use to plow with your compact and utility tractor? Front loader? Back blade? Plow? Etc? I get the impression that the standard loader bucket is a bad choice, as it digs up the pavement, packs with snow, and is very inefficient. Agree?
2. In the commercial market, the following things are important. Getting down to bare pavement, no breakdowns, and no damage if someone hits a curb or manhole cover. What is most important to you?
3. Do you use tire chains?
Trying to figure out what I need to get to do this job right.
I made a bolt on plow frame for my bucket and a small truck plow. The plow pivots via the electric hydraulic pump.
/ Questions about snow removal. #26
I have a Mahindra 3616 36 HP 4WD and it's a plowing machine. Our driveway is 600 feet long with 400 feet of 5% grade. After two years in upstate NY, I'm thrilled with plowing snow with my rig. I have a regular 7' "truck" snow plow welded to a quick attach mounting plate for my front end loader (like Dwellonroof showed). My tractor didn't have 3rd function hydraulics for the plow blade angle, so I purchased the WR Long 3rd function kit made for my tractor and installed it myself. The rear tires have ballast and I have a 3 pt hitch ballast box full of sand. These are important. I also use rear only tire chains. I tried getting by without this investment, but with any hill or melting that leaves some ice, life gets hard. I also installed a block heater which I set on a timer the night before a storm so that the engine gets about 2-3 hours of heating before I fire it up. I have a hard canopy made of a golf cart roof. This let's me add a thrifty cab in the winter by draping a golf cart rain enclosure over it. A few bungees and clamps keep most of the wind off me. Once I added the enclosure, my engine exhaust built up (mine exhaust front left). So I extended the exhaust along the loader the frame rail to the back of the rear axle. Works great. PM me for more details/conversation/advice.
/ Questions about snow removal. #27
They use this style machine to plow parking lots here in idaho. They chain a snow bucket to loader bucket. But they suck in small, tight spaces. And when you swing around make sure you don’t hit anything with the backhoe.
I ran a hoe like this for years. Very good digging and hauling dirt. But driving empty was always a seesaw ride. Lots of rear end weight.
/ Questions about snow removal. #28
i clear about 20 driveways. until last year, i used a kubota b2400 with soft cab, and a 60" farm king snowblower, and a bucket on the front. i'm in PC utah (~300" annually - light an fluffy except for early and late snowfalls). almost all my driveways are asphalt of concrete, only one gravel. almost all ridiculously steep.
i don't have too much trouble with the steel edge on the concrete, but i have to go light on the asphalt. gravel i can't use the snowblower until the ground gets frozen enough, so back blading with the bucket is really the only option there.
the biggest issue i had was transit speed. i'm not making money between jobs, and i have a day job also. i start moving snow around 0430, and have 2 hrs to do all the driveways.
that's why i've upgraded to a l3800, with a 72" woodmaxx. next year i'm getting a 72" snow pusher for the front. the bucket is terrible for garage doors.
i do not use chains. mostly because they'd slow me down. that said, R1 tires suck. i hear r4s suck even more. if you need to work on the steep and deep, consider grooving and siping those tires. i siped my fronts (i do a lot of backing up hills, and they were cheaper to replace if i f'd them up. the siping did wonders. i'm grooving and siping the rears over the off season. can't afford r14s. that's a little rambling, but it's what i do. hope you find something useful in here.
/ Questions about snow removal. #30
I have a Ford 2120 40 hp 4WD, and have been using the backblade for about 10 years for plowing in SW Montana.
It works pretty well -- but, does give you a crick in the neck :)
Driveway is about 1/4 mile long.
I find that for really tough snow, the backblade will tend to push the back end of the tractor inward. Under these conditions, I rotate the blade 180 degrees so its facing backward, and then backup to plow - this helps.
It pays to push the early snowfalls well off the driveway because if you get a lot of snowfall later in the season, it gets hard to maintain the full width of the driveway.
I find the front bucket to not be very good for plowing.
I've thought about getting a PTO snow blower, and I'd guess it would work well, but probably not enough better to justify the cost.
Gary
/ Questions about snow removal. #31
The first thing to remember is a tractor with a loader is not a bulldozer. When you talk about hitting a manhole cover I can tell you from experience that you can do some serious ($$$$) damage. If you look at some of the posts in this thread of front mounted plows they use trip springs to prevent damage to the loader and hydraulics.
The advantages of using the loader are you can put down force (actually lift the front wheels off the ground) where as the 3pt hitch can't. It makes a big difference with some of the snows we get (like the wet compacted stuff that's been driven on). A loader mounted plow also can be very useful to push piles back and get them much higher. For the deep snow you'll occasionally see I would go with a snow blower first and if not then a plow on the loader (with trip springs).
/ Questions about snow removal. #32
Well, I live in North Central Massachusetts and have used them all. The front bucket is slow like others said and you have to dump often if you have a lot of snow to move. The back blade works just OK but we get a lot of snow and pulling it just doesn't work I spin the blade around and push it... but it loads up too. I tried to angle the blade but I have industrial tires (4wd) and all it did was load up and push the tractor to the side. Oh... and I do use rear chains. Was told NOT to put them on the front with 4wd.
My driveway and the road to my barn are both gravel with some slight uphill. Couldn't do squat without the chains.
Last year I purchased a rear 5 foot snowblower. While it works great... it's a bear on the neck and back, driving backwards all the time. But.. it is much faster.
I forgot what type of tractor you might have said you have but if you have a mid-PTO then get a front blower. If not and you get a higher amount of snow then the rear blower is the way to go.
That's my 2 cents and I'm stickin' to it (until i get another tractor with a mid-PTO). I wasn't smart enough when I bought the Kioti CK30HST but it's been a FLAWLESS tractor for 13years now.
/ Questions about snow removal. #33
This pic from about 5 years ago was roughly a 20” snow, hard to say, lots of drifting. The drift up ahead of the tractor is about 6 feet deep. I did my driveway and the neighbors driveway using just the end loader, pic is my previous tractor. This is looking down the township road at about 1:00 pm. I didn’t know when or if they were going to clear the 1/4 mile to the county road. It took me several hours to clear it.
My point with the pic is the rear blade or any front blade is useless, there is no place to push the snow. A blower is the real tool to have if you get these kind of snows on a regular basis. We have lived here 24 years and it’s the only snow like this we have had.
/ Questions about snow removal. #34
Ya, I use my front blower every year to clear drifts. I blow them the direction wind is blowing so it doesn’t just blow right back over the road. With drifts, a tractor plow just doesn’t cut it. The plows attached to a large dump trucks can move them though.
/ Questions about snow removal. #35
I will be the odd man out, I came from plowing with an atv, and 300 feet of gravel with hills. I put a set of edge tamers on the bucket, and i can push over a foot the entire length of one drive with pretty much 0 issue. I did groove my r4 tires and that helped a lot.
That said I cut my plowing time in half, and with it all hydraulic and power steering, almost 0 effort
I strongly recommend you try it before spending money.
I WAS buying a blower. I am NOT buying one now after one season, and we got 2 feet in one storm.... if your trying to make money thats a different story.
/ Questions about snow removal. #36
Have any pictures you can share of siped R1s
here you go. i made them about every 3/8" and about 3/8" deep (10mmx10mm for people happier with metric)
/ Questions about snow removal. #37
Did that help with lateral traction.
My issue is that when I'm pushing snow that the snow will push the front of the tractor left or right. Or when trying to make a tight corner that the fronts will slide to the side. Or when I'm going in across a slope I need to steer up the slope to go straight and the front will still slide down the hill. I've got no problem in the back because I use studded chains in the winter. I don't want to put chains on the front for fear of damage to the front axle, couldn't live without the 4WD in the winter now that I have a tractor that has it.
I put a couple of shallow grooves in my fronts running parallel to the sides of the tire trying to mimic some tread patterns I've seen, but this did not help much, if at all. Lugs on my tire do not appear as deep as yours from the photo.
I get a lot of ice and slippery conditions on hilly areas here and I have yet to find a solution to prevent the lateral slipping. It's something I've lived with for a long time, been here 26 years and have almost always had some type of tractor for moving snow. I've pretty much learned to deal with it and have only started to look for a solution since reading threads about grooving and sipping tires here on TBN.
There was another thread about Carlisle Vera Turfs that I followed but the person that tried them said they were still seeing the lateral slipping with them so not something I'm going to replace new tires to try at the cost to find out I'm no better off. Besides, I really like my R1s on my hills, I've seen all kinds of tires spin on damp ground going up the steepest parts of my property and only the AGs give me the traction I need.
/ Questions about snow removal. #38
This pic from about 5 years ago was roughly a 20” snow, hard to say, lots of drifting. ...
That's what it looks like around my house from about the second week of January through mid March every time it snows. Lot's of wind here. A snowblower is slow but anything less than the trucks the town uses isn't going to plow it. I have to pull the deepest parts of the drifts down with the bucket before I can blow the snow away. A lot better, some might even call it fun, now that I have something more suitable to the task. I would have gone bigger but wouldn't have anywhere to store something bigger.
/ Questions about snow removal. #39
I cannot fit "standard" (such as Aquiline) chains on my tractor's front tires and turn (steer) the wheels owing to clearance problems. I do not have hills and have not had traction problems so the question is moot for me.
Thule and Koenig make chain sets with much smaller chain to fit cars like sport sedans that have very limited clearance. These are often designed with some "easy attach" system and are marketed for urban skiers to meet California and other western states chains in the mountains requirements. They do have some links arranged circumferentially near the center of the tire treads as opposed to the axial orientation of "ladder" chains so they might help with directional control. I have experience only with the Thule brand and have had good results with my Honda Accords in ski country (NH). Google "Thule snow chains" to see if they are available in a size to fit your front tractor tires and might otherwise be suitable for you.
/ Questions about snow removal. #40
I plow with the FEL and a rear blade. I am chained up on all 4 and have 4 wd, R4s. I do have a front mount blower but found that it plugged up with wet sloppy snow more often, so I took it off and just use my bucket. I have teeth on the bucket and a gravel driveway. The way the teeth are on the bucket, I leave an inch of snow behind after every snowfall, but to me it doesn't matter because if I wasn't plowing in the winter then I would have nothing to do. I retire every winter and only work in summer. My cab and heater keep me warm enough that I can plow in a T-shirt.
