Question on Rotary Cutter
/ Question on Rotary Cutter #1
Esprings240
New Holland TN70A
Would a Woods Rotary Cutter BB720X be too heavy for my TN70A New Holland? The cutter weighs 1200 without chain shielding. I am planning on ordering chain shielding front and rear so it would be slightly more. The tractor weighs just over 5700 with no implements and presently has a Bush Hog loader 4045 attached. I do not know its weight.
Also the PTO rotates clockwise and the cutter lists the blade rotation as counter clockwise. Am I right in guessing that the gear box takes care of this?
/ Question on Rotary Cutter #2
Looks to me like you'll be fine, your machine is rated for close to 4K lbs on the 3pt. Rotary cutters are hard because the weight is so far back, but I'd be shocked if your machine couldn't lift it.
Yes, the gearbox changes the speed and direction of the rotation, nothing to worry about there (unless it's something totally unique to Woods; they do make gearboxes that go the "opposite way" but they are oddballs for things like batwing cutters where you have a splitter and multiple gearboxes).
/ Question on Rotary Cutter #3
I’m not sure how my tractor (M6800 Kubota with FEL) but I have the BB720 (a great cutter). I have no problem whatsoever. Do you have an FEL or front weights?
/ Question on Rotary Cutter #4
The OP said he had a BH 4045 loader so he should be set on front weight.
/ Question on Rotary Cutter #5
The bulk of the weight will be on the cutter’s wheel, so you won’t have any issue.
/ Question on Rotary Cutter #6
I run a BB720X on my DX55, and it's a perfect fit in my opinion. I have chains front and back too. Your 70 will handle it like a toy. Woods does offer 3PH limiter chains too, so you can let the weight of the cutter hang on the chains rather than bounce on the 3PH. I got a set for mine, but they don't fit due to the several hydraulic couplers on the back of my 55.
/ Question on Rotary Cutter #7
You'll be fine, my brother used a Land Pride 6' cutter on a TN65 and it handled it no problem. With your tractor being a tad bigger and the cutter about the same you will love it.
/ Question on Rotary Cutter #8
You might want to order it with dual tail wheels, if weight is a concern. I would love to have a BB720!
/ Question on Rotary Cutter #9
do you have loaded rear tires? ballast is helpful on a compact machine w/a cutter of that size. your fel will also no doubt help, best regards
Thank you all for responding. I found out today that Woods has discontinued production on the BB720X. New model is not scheduled for release until 12/1/19
/ Question on Rotary Cutter #11
Any information on what is changing? We were looking at purchasing a BB720x.
No information yet. I sent a query to Woods website. No reply yet.
/ Question on Rotary Cutter #13
Sawyer Rob on here reported a Woods rep told him earlier this year "it would be in his 'best interest' to get one sooner rather than later" due to a redesign coming up. I found dozens of new BB720's available on TractorHouse.com, but ordered one from a semi-local dealer who's treated me well in the past. I didn't want to wait for the redesign, since I haven't seen many implement changes recently that made things heavier or more sturdy. Most changes these days are to cut costs.
/ Question on Rotary Cutter #14
I am thinking the same thing ^^^, accountants involved to lower cost, not engineers to improve. I would the current version without seeing the new one.
/ Question on Rotary Cutter #15
Thanks Guys,
I'll call around and see if I can find one this week.
/ Question on Rotary Cutter #16
I run a BB-720 on a Kubota L5030 with no FIL and did have to put liquid ballast in the front tires but it handles it fine. Your tractor should be fine. I love the 720, it’s a beast!
Jkub
New/Unused 78in Quick Attach Grapple (A65583)
New/Unused 78in...
New/Unused 6ft Quick Attach Brush Cutter (A65579)
New/Unused 6ft...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
3ft Metal Rooster (A65583)
3ft Metal Rooster...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
