Question on Plow size
/ Question on Plow size #1
Michigan_Mike
SE Michigan
Deere 790
What are the advantages and disadvantages of the different sizes of plows?
I've been talking with a local dealer who sells 12" and 14" moldboard plows (1 and 2 bottom in each size), and I'm not sure which way to go.
I have a JD 790, and the soil is pretty good (not clay), so I THINK I can handle any of the 4 configurations.
Does the 14" just dig deeper?
Is that necessarily a good thing?
/ Question on Plow size #2
Well, even though you dont want to go to out local chapter meeting, I'll answer this. /forums/images/graemlins/grin.gif
you might be able to pull a 2-12 in sandy soil but that would be it. The size means working width of the furrow so the 2-12 would give you a 24" furrow.
/ Question on Plow size #3
Generally speaking, a plow should be used at a depth of around 1/2 of it's width. So, that 12" plow would work at 6" deep. You can USUALLY plow an inch or so deeper. The wider the plow, the rougher the surface will be left (Also generally speaking) Wider plows tend to deal with "trash" better. (corn stalks, weeds, ect) In the late 70's/early 80's, moldboard plowin fell out of favor on big farms for several reasons. The last years of it's popularity, WIDE plows were the norm. 18"-20"even 22" wide bottoms weren't uncommon. That left the surface rough. That was by design. The rough surface resisted wind and water erosion. It also left small "furrows" that helped hold water to be absorbed into the ground (in areas plagued by low water levels)
A 12" plow will pull MUCH easier than a 14". It is 2" narrower, as well as works better at 2" shallower. From my experience, 3 x 12" will pull easier than 2 x 16". Consider how much of an area you're plowing. If it's a relatively small area, such as a garden, you'll be starting and stopping quite a bit, as compared to a 100 acre field. Go with a plow that is well under the "load" you can pull at maximum. That will be MUCH easier on your clutch/transmission/engine/ect....
/ Question on Plow size #4
If that 790 is around 30HP? You should be able to go with a 2-12 or a 1-16. The 2 bottoms pull much easier than you would imagine. A TO20 Ferguson 55 years old and 20 hp, has no problem with a 2-12 configuration. As discussed on this forum in the past, most old timers that have been around a while had rather have a good used older plow, ie Dearborn-Ferguson-JD than 2 of the new TSC type plows.--Ken Sweet
/ Question on Plow size #5
You need to find the pulling or ripping force of your tractor config then calculate the pulling force needed by the various plow configurations & pick one at or below your tractor config limits.
It's a numbers matching game. In general terms you want 7-10% wheel slippage at 3-5 mph for most efficient power transfer of the tractor into the ground. Turning topsoil only - not so deep to bring up subsoil. Set coulters deep enough to only cut trash. They take extra HP but make pretty furrows. Follow your plow manual for adjustments on the 1st 2nd & 3rd cut. The birds will follow you picking out worms. In the unlikely event you make a mess disc it out quick and follow up with a cultivator tine harrow or spike harrow. Nobody will know!
Some people complain about hard pulling plows - it's because they didn't bother to set it up properly!
Add in the roots, rocks, slopes, weather conditions & the practical advice given here on the TBN board & you should be good to go!
/ Question on Plow size #6
A few years ago I bought a 3 bottom Ford plow. I had a tractor big enough to pull it, but didn't have a clue how to set it up or how to plow. I made a big mess of that field. It looked like the ocean on a real windy day. The local good ole boys got quite a laugh at my expense. I have since learned how to plow and enjoy doing it. You know, this farming thing is a great hobby and I love doing it, but don't let anyone tell you that it is easy. Experience is the best teacher. I've made a lot of mistakes and spent a lot of $ with my trial and error experiences. It's a good thing I have a real job to pay the bills. I'd be bankrupt if I had to depend on farming.
That's why I'm on this list.
If I didn't have to ask these basic questions, I would have more time to attend the meeting. /forums/images/graemlins/grin.gif
Thanks for the advice. Sounds like I need to avoid the 2-14
Thanks for the information.
My initial thought was that with a 2-12, I could get it done in half the time as a 1-12.
But seeing that I wil be doing small areas at a time, the difference woud only be 2 or 3 hours.
I agree Ken. I would have preferred to get a used one, but they don't show up very often. And when they do, if you're not driving the pick-up and have cash in hand, by the time you get back, it's already sold.
As a side note, the dealer isn't TSC, but a local farmer who also sell implements. I think the brand he sells is Western?
I'll be ready as soon as the snow is gone. /forums/images/graemlins/grin.gif
Of course, that might not happen until July.
We got another 2 inches last night.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2002 International 9200i Truck (A61307)
2002 International...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
2008 Ford Explorer SUV (A60352)
2008 Ford Explorer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
