Question on BX series loaders
   / Question on BX series loaders #11
</font><font color="blue" class="small">( Northwood Equipment (Northwood, NH ) - Massey dealer - LOTS of equipment on the lot. I did not talk to anybody since I was there late one night. A little far away for me.
Markwell Equipment (Merrimack, NH ) - Massey dealer - not a huge amount of equipment on the lot but they were the closest Massey dealer to me.
)</font>
Jim, Markwell is owned by Northwood Equipment. They also own Allenstown tractor.
Phil
   / Question on BX series loaders #12
8) I considered the dual cylinder vs single cylinder thing on the FEL's but could not find anybody who could tell me unequivocally either way whether one was better or not. One salesman said the dual cylinders gave more equal pull/push on the bucket when digging, another told me that the single cylinder was less likely to get damaged from stuff falling out of the bucket than the duals were. This was one was a draw for me. )</font>
I have never had a problem with the single cylinder. One thing to keep in mind though - if you plan to have chain hooks welded on. Some have just welded one in the middle, but I had one put on each side of the bucket. I simply make sure to balance the load by wrapping the chain around both and put the load in the middle. I would think it would not be good to put all the load on one side.
Best to you on your purchase - you WILL enjoy this little beast!
Terry
Thanks Tim for the info. Actually the only Kubota dealers I have visited so far are Chappel and MB. Chappel is closer to me and their quoted price was better so for me so far they are at the top of the list. I was going to devote this week to shopping around so if you have any other Kubota dealers you would suggest please let me know. Northwood Power seemed like a really nice dealer - I just got up there too late to talk to anybody. I was actually willing to do some traveling to get a good deal on the BX23 if that is what I have to do. I had another tractorbynet poster recommend Pinnacleview in Keene and I had them on my list of dealers to call. I had another dealer from PA offer to sell to me but I have not heard back from him yet. I would like to avoid a 500 mile trip to get a good deal but NH, VT, CT and RI are within reasonable distance for me. I live in MA and was going to avoid buying here because of the sales tax. So if anybody has suggestions on other Kubota dealers to talk to I am interested.
There were a couple of other things I noticed in my comparison of the GC2310 and the BX23 that I forgot to put in my previous post. The tire sizes on the GC2310 are slightly different than the BX23. The front tires are on a 10" diameter rim vs. the 8" diameter rim on the BX23. I don't know why they do this but after some searching on the web I found that you can get 8ply tires for correct size to fit the backs on both tractors. I could not however seem to find 8plys to fit the front size on the BX23 but I did find an 8ply to fit the front on the Massey. I am not sure what ply tires Massey uses on the bars but the turf on both BX23 and the GC are 4 ply as are the bars on the BX23.
I only mention this because jpr62902 responded earlier in this thread that the front tires on his BX23 pancaked pretty good when he had a heavy load in the loader. This got me wondering whether heavier duty tires were available. According to the stuff I read for the rear tire size on both tractors a 4ply tire is good for 1780 pounds, an 8ply is good for 3020. I am sure there is the same sort of improved load rating on the fronts if you go from 4 to 8 ply. Since I plan on buying both turf and bar tires for my tractor I may go for the 8ply tires on my BX23 - and the rims on the Massey appear that they will fit the BX23 - so using a Massey rim (painted the appropriate color orange of course) may be a solution for the problem of 8plys not being available to fit the 8in rim on the BX23 fronts.
You mentioned the 3pt arrangement. This is one piece that was not on the top of my list since I do not anticipate using 3pt implements . However the BX23 3pt has to have it's arms removed to attach the backhoe. The BX23's in the yard at Chappel have a box attached to them that I assume has the arms in it. The arms on the GC fold out of the way and allow you to attach the backhoe without removing them. I also think they are standard size Category 1 instead of the off - size of the BX23.
The other thing I noticed about the BX23 vs the GC2310 is that the BX has a fuel level and a temp gauge. The GC only has a fuel level.
   / Question on BX series loaders #14
Since this is a BX23 Loader info thread, here are some action shots of my BX23 loading a bunch of broken up sidewalk cement.
   / Question on BX series loaders #15
Another...
   / Question on BX series loaders #16
Last one...
   / Question on BX series loaders #17
If you do decide to change the front wheels, be sure that you get a tire that maintains the front to rear ratio. If you don't the drive line will be in constant stress and the tires will have a very high wear rate.
   / Question on BX series loaders #18
Botaguy, did you break up the concrete with the BH?
I have a 12x15 patio that I need to break up, but will likely rent a jackhammer. Besides, I only have a 2200!
THKS.
Ron
Thanks for the pics BotaGuy - I like to see that I will be able to do that kind of work with the BX23. Thanks also to JerryG for reminding me to check the diameter on the front tires. If I understand the tire sizing correctly they should be the same diameter. The sidewalls on the 18x8.50-10 tires on the GC2310 are quite obviously lower than the sidewalls on the 18x8.50-8 tires on the BX23 so I believe they would be stiffer. Looking at the John Deere site last night I noticed that the Deere subcompact size tractors use the 18x8.50-10 front tire size also. IF I end up making this work I will post the results.
   / Question on BX series loaders #20
NO, I didn't break it up with the backhoe. I rented a Bosch electric jackhammer and it was not very effective. It took about an hour and lots of body punishing to break up one section of concrete....NOT FOR ME!! I rented a Bobcat 763 with a hydraulic breaker on the front...This is clearly the right tool for the job. It took about 45 minutes to break up the rest of the walk!!! It cost about $120 to rent the Bobcat and breaker but it was money well spent. Then I moved all of the concrete with the BX. The BX is like a little tank it will move an impressive amount of material.
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2009 Wilson Hopper Bottom (A59814)
2009 Wilson Hopper...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
