QUESTION: any problem adding larger front tires?
/ QUESTION: any problem adding larger front tires? #21
Why would the manufacturer offer two different size (circumference) rear tires with the same fronts if it was outside of the acceptable range?
I believe that is because the wear will still not break anything until after the warranty. Why should they care if you break your tractor in 6 years? More money for them. Yes, I am cynical. Serious, too.
/ QUESTION: any problem adding larger front tires? #22
T
Your assertion that normal wear is OK so why not bigger tires on one end or the other. Normal wear can be understood by the manufacturer and the system is capable of coping with this change when the original ratio of diameters is utilized. Once you inject a new variable, larger tires on one end or the other, into the system, the envelop is subject to changes outside the original design. Example, the rears have two inches of wear to the bar tread which assuming stock fronts, new or not is OK. Add two inches to the front and subtract two inches from the rear and now you are out not two inches but four.
I just hate to see a guy damage his drive line on the assumption that "diameter doesn't really matter", "that much". I would want specific information from the OEM....that's all.
Cheers
That isn't my assertion. Wear was just one of the variables I mentioned. I also mentioned that the OEM offers two different sized rear tires, with the same front tires, so there is clearly a range of acceptable size combinations. Also, I never said diameter doesn't matter, I just said the folks stating, with absolute surety, that it will cause damage don't know what they're talking about. They don't know the mechanical ratio between the front, and rear tires, and haven't figured out the difference in lead....in short, they're guessing.
I'm the one suggesting to figure it out with specifics before deciding either way.
/ QUESTION: any problem adding larger front tires? #23
Auto, and tractor systems aren't the same...evidence vastly different size tires on tractors to start with.
Did you run the numbers through the formula on the site I linked?
Recoveryhill explained it nicely I think.
Gman, if TSO decides to go with the larger tires based upon your argument, are you going to warranty any premature failure?
I still say to swap on a set of 10 plys and be done with it. Cheap and effective. Sorry, no chart or link here...it just worked for me.
/ QUESTION: any problem adding larger front tires? #24
All I'm saying is to figure it out using a formula rather guess. That way he won't waste money, or do any damage....simple, smart, and cost-effective.
/ QUESTION: any problem adding larger front tires? #25
Maybe. The formula was obviously made by a smart guy. I've been dealing with smart guys for over 35 years...guys like engineers and architects. Ever heard of a change in a set of plans / drawings made during a build? How about structural failures on buildings built to specs? As much as we'd like them to, formulas and calculations don't always work out in the real world. I'd err on the side of caution myself.
/ QUESTION: any problem adding larger front tires? #26
Hello folks. The fronts will have an lead ratio ie they cover a bit more distance than the rears on a properly setup tractor but its only something like 0-5%. Several Kubota models including mine have 10-16.5's and actually lag which isn't good. I replaced them with 12-16.5 on my L5030HSTC but the lead ratio is excessive so you can only use 4wd on slippery surfaces or I will bind and wear the gears etc excessively.
Someday I will replace the rears as well to correct the ratio but I'm soon to be on my 3rd set of fronts while the rears are barely worn. Just shy of 2000 hours.
/ QUESTION: any problem adding larger front tires? #27
Hummmmm....I guess then we are in agreement, almost.
Don't stick bigger rubber on one end of your FWD tractor until and unless you have "figured out" the mechanical ratio between the front and rear tires and haven't figured out the difference in lead. Sounds like good advice to me assuming the source of same is the manufacturer of your tractor.
Thanks for suggesting how to do all of this and asserting that Rice University "The Cereal Knowledge Bank (CKB) is the worlds leading repository of extension and training materials related to cereal and cereal production" is the ultimate source of guidance, not the OEM design engineers of your particular make of tractor.
Over and out....
/ QUESTION: any problem adding larger front tires? #28
If you change sizes you probably wont be able to move it without it bucking around. Mine is starting to with just front tire wear. Rears still look new.
/ QUESTION: any problem adding larger front tires? #29
All you need to figure out the mechanical ratio between front and rear tires is a jack....no need to talk to the tractor manufacturer. TSO is a pretty resourceful, bright dude, and I'm confident he could manage that one with no trouble.
Over and out? It's one or the other, not both....both makes you look look like a 70s sitcom, and that isn't a fate any TBNer deserves. :eek: Over means "it's your turn to talk"; out means "I'm hanging up". Out.
/ QUESTION: any problem adding larger front tires? #30
I would bet even your stock tires are not the perfect size to prevent binding in the drivetrain. I have a Newholland 4wd TC30 with a little over 200 hrs, so not much tire wear. A portion of my driveway is paved and steep enough that it is faster to put the tractor in neutral and coast, there is enough resistance between the front and rear axles when 4wd is engaged that I can tell the difference in speed from 2wd.
/ QUESTION: any problem adding larger front tires? #31
Nobody here yet has talked about why there is lead in the front axle. Mostly it's there because when you turn a corner the front tires travel a longer distance than the rear tires and if the lead isn't there then when you turn, the front tires hold back the turn. If you want to experience the front tires holding back just try making a sharp turn on dry hard ground, no loader, with inside wheel brake on in a sharp turn. Do it once in 4x4 and once with out. You'll make a sharper turn without 4x4. Years ago on my 4410 I switched my front 27x8.5x15 out for a pair of 26x12x12. Yes they are a little smaller but that was the closest size I could come up with at the time. Yes my tractor doesn't turn as well in 4x4 as it did with the 27's but I don't have as much slippage on the straight with the 26's as I did with the 27's. My solution in the dry is to turn my 4x4 off for sharp turns. In the wet there is enough slippage that it doesn't matter. The 26's added the flotation and the traction that I wanted and I was willing to live with the other compromises. 2000 hours, two sets of front tires and no problems so far.
/ QUESTION: any problem adding larger front tires? #33
With some work you can find out 100% what each wheel turns.
Jack up the entire tractor and block it up. with some help keep it locked n 4wd, have a friend watch as you turn the rear wheels exactly one turn. Watch how many turns the front wheel has turned. you can then use how many revolutions the front wheel turns to each turn of the rear wheel. Some thing else to take into consideration is to use the rolling diameter. set the tractor back on the ground and measure the radius, from the centre of the axle to the ground and multiply by 3.14. use this number. the distance traveled by one complete revolution of the rear should be matched by the front axle.
I have done this with polaris atv's and side by sides. the front and rear axles turn at very different speeds on the earlier models. My 01 sportsman turn 22% faster ont he front axle. No wonder the machine was a beast to steer with tracks on.
/ QUESTION: any problem adding larger front tires? #34
When I bought my tractor (L4200) from a company,
it had, and still does have 28's on the rear.
The specs call for 24", they had several tractors like this one, all had 28's.:confused:
Always kept in 4x4 and never had issues. (GST drive-train)
Personally, I don't see a problem, run it it 2x4 in summer, and 4x4 in winter.
/ QUESTION: any problem adding larger front tires? #35
When I bought my JD 4500 new, I had a choice of 13.6 X 28 or 14.9 X 24 rear R1's, both with the same 8 X 16 fronts. The lower sidewall of the 13.6's made them close in height to the 14.9's, but there was still approximately and inch on OAH difference checked sitting side by side in favor of the 13.6's. The actual rolling radius/circumference was even more, yet they were both sold with the same front tire. I asked several Deere dealers about this, including my own, and they all said the same thing- there is a certain range that they can vary and still be within design specs/tolerances, at least on the JD's.
/ QUESTION: any problem adding larger front tires? #36
This thread is making me glad I was too poor to afford FWD.
Thanks for all the comments. I did a quick measurement last night, the 10x16.5's are roughly 29.5" tall, while the 12x16.7's are about 31.75" tall... so the sidewall height difference is about 1.125".
I'm going to call the dealership today and see what they think.
Ok, dealer says no. Says not to change the ratio, will damage the front end.
I guess that settles it.... poop.
/ QUESTION: any problem adding larger front tires? #39
Ask them what the mechanical ratio is....hint, they won't know.
I don't think it's enough difference to worry about, but all the folks screaming it will cause problems are doing so based upon opinions, not math. The front end only cares about the math.
I know, but since he's (the dealer) the one that would be doing warranty work on it, if something does break, he might not be able to get it covered
Fuel Storage Tank (A68134)
Fuel Storage Tank...
2009 FREIGHTLINER CST120 (A67714)
2009 FREIGHTLINER...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2016 FREIGHTLINER CORONADO 122 SD (A67714)
2016 FREIGHTLINER...
(INOP) 2005 CATERPILLAR 535B SKIDDER (A65056)
(INOP) 2005...
2007 (INOPERABLE) INTERNATIONAL DURASTAR 4300 (A67714)
2007 (INOPERABLE)...
