QUESTION: any problem adding larger front tires?
/ QUESTION: any problem adding larger front tires? #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
Just picked up a new Massey 1648. It came standard with 10x16.5 R4's. I prefer the 12x16.5's that are on my LS. The wider/taller tires helped with stability and floated better.
We're only talking a couple inches difference. Would that cause any harmful problems to the driveline? If so, what?
/ QUESTION: any problem adding larger front tires? #2
If it is four wheel drive yes it will be problem. The tire sizes are matched to the gear ratios of the front and rear drive lines so that they work in sync. If you put larger front tires than stock they will try to make you go faster than the rear tires will which means either the fronts or rears are going to be constantly slipping. I would not recommend it
It is 4wd, and I thought about that, but what makes me wonder is that you can get different sized rear tires as an option, with the same size fronts.
/ QUESTION: any problem adding larger front tires? #4
Your bucket might not go low enough for optimum digging and a vertical muffler/exhaust pipe might be tilted back a bit. I noticed this when I put used aircraft tires on the front of my 2WD MF. I was able to lower the bucket a notch by moving a pair of pins. Couldn't do anything about the exhaust, I hope it's only cosmetic.
/ QUESTION: any problem adding larger front tires? #5
Are you sure the front tires would be the same size?
The tire options (for MFWD machines) on the Deere site indicate specific tire sizes (depending on the type of tire) for their tractors.
You could check with a dealer...but I do think you'd cause drive train problems.
/ QUESTION: any problem adding larger front tires? #6
If the front of the tractor is raised higher than the rear. The tractor will be rolling uphill and will therefore use extra fuel.
/ QUESTION: any problem adding larger front tires? #7
The distance covered in one complete revolution of front and rear tires on a Four Wheel Dive vehicle needs to remain as specified when the front drive gears were engineered. Go smaller and the drive line will be in a bind trying to skid the front rubber forward. Go larger and the front rubber will be trying to outpace the rear rubber and result in a bind with opposite forces.
For Example:
3.1416 x Diameter = Circumference
Circumference (rolling distance of one revolution) on a 24" tire is: 75.4"
Circumference on a 26" tire is: 81.7"
Adding 2" to the diameter would result in the tire traveling 6.3" further for each revolution too much for a drive line that requires a fixed ratio of circumference between rears and fronts. Tire width doesn't matter....within reason.
/ QUESTION: any problem adding larger front tires? #8
So, if the rear is higher than the front, could you get by with no fuel? :laughing:
Yeah, you can also get the rears in 17.5Lx24, which are wider but slightly shorter than the stock 14.9x24. But the front tire size remains the same.
/ QUESTION: any problem adding larger front tires? #10
Since you have both tractor there now, why not measure the rolling distance on both fronts and verify that they are the same or nearly same. They may be wider but no difference in OD. If they are the same, you could even swap them out between the tractors
The fronts are definitely a different height ... not sure if you viewed the pic yet, but it's pretty apparent. The rears might be close.
/ QUESTION: any problem adding larger front tires? #12
For Example:
They offer different size rear tires on that machine with the same fronts...17.5Lx24 are an option, which are slightly shorter than the stock 14.9x24. That would change the ratio just as much as keeping the rears stock, and going up in size on the fronts.
Further, what about normal wear on tires? It wouldn't be uncommon for the fronts to wear much quicker for someone doing a lot of FEL work, but there isn't a spec in any manual I've seen stating that you have to replace the front tires when they are worn down beyond a particular size. If this was truly an area of concern, there would be a ratio listed in the owner's manual advising you that driveline damage could occur if you stray outside a certain ratio from front to back. Sure, putting tires that are vastly different on the fronts could be an issue, but something like TSO is talking about isn't drastic.
/ QUESTION: any problem adding larger front tires? #13
As someone stated, switching to larger tires only on the front can bind and damage the drivetrain, even in the dirt. I would switch to 10 ply R4 skid steer tires in the same size. You can even get them wider with a close enough diameter. I replaced my 6 ply Titans with 10 ply and the difference is substantial. Less sidewall flex and less chance of popping a bead. SS tires also have nice thick rim guards.
/ QUESTION: any problem adding larger front tires? #14
Rather than theories based off what some guy said, somewhere, on an Internet forum, here's a way to calculate acceptable tire sizes:
Hint, there is a range of sizes that will work, and not cause damage (again, if that wasn't true, normal wear would cause damage).
The concept of front-wheel drive assist
/ QUESTION: any problem adding larger front tires? #15
Nice, but a 2" dia. difference will lead to excessive drivetrain wear at the least. My background is in 4wd offroad vehicles, mainly rockcrawling. Matching ring and pinion ratios with the same height tires is important, even in sand. Only in snow can you get away with more because of the slippage. Even sand and mud dragsters using larger tires on the rear change the r&p's to match the difference in tire height and they're basically spinning the entire run. Drive a 4wd truck out in the dirt with 31's on the front and 33's on the rear and you can feel the bind through the steering wheel. It's not internet lore, it's the real deal.
So are you suggesting that if I want larger front tires, I need larger rear tires as well?
I believe 16.9x24 us the next industrial size up, but dang those r pricey!
/ QUESTION: any problem adding larger front tires? #17
At one time, I'd thought about going to larger tires on my R3039H. Dealer said that I could do it, (all four tires / wheels) but at the tune of about $3000, I decided I liked mine just fine, as is !
yeah I'm fine with the rear tire height; though I would like them to be wider like my LS tires. It's just the fronts is want taller/wider.
/ QUESTION: any problem adding larger front tires? #19
Auto, and tractor systems aren't the same...evidence vastly different size tires on tractors to start with.
Did you run the numbers through the formula on the site I linked?
Why would the manufacturer offer two different size (circumference) rear tires with the same fronts if it was outside of the acceptable range?
/ QUESTION: any problem adding larger front tires? #20
The different size tires, front to rear are accommodated by gearing which compensates to equal the same rolling circumference, i.e. the smaller fronts are geared to rotate faster than the taller rears, a set ratio with no elastic in the works. All four wheel drive systems, even between auto manufacturers differ in the bits and where they are located. No four wheel drive system is different in that the bits need to make sure the distance rolled by both front and rear tires is within a fairly tight specification.
Your link provided information on "lead" relative to rolling circumference for tractor operation in various media, sand, rice paddy, etc. Interesting and new information for me, thanks.
Your assertion that normal wear is OK so why not bigger tires on one end or the other. Normal wear can be understood by the manufacturer and the system is capable of coping with this change when the original ratio of diameters is utilized. Once you inject a new variable, larger tires on one end or the other, into the system, the envelop is subject to changes outside the original design. Example, the rears have two inches of wear to the bar tread which assuming stock fronts, new or not is OK. Add two inches to the front and subtract two inches from the rear and now you are out not two inches but four.
My fronts have a nominal OD of 27", the rears 42". The difference in rolling circumference is 47.1 inches per revolution, a difference taken into account by Kubota engineers when they set the gear ratios. Say I go to new 29" OD fronts and the rears have worn 1" per side and are now 40" OD. The difference in rolling circumference is now 34.5 inches, a 30% change in the numbers the OEM designed into the driveline as opposed to a 15% change if I put new fronts (27") on a tractor with worn rears (40"). That translates into a 100% change in expected rolling differential.
I just hate to see a guy damage his drive line on the assumption that "diameter doesn't really matter", "that much". I would want specific information from the OEM....that's all.
Cheers
2021 Topcat SSSTG200 Stump Grinder (A62679)
2021 Topcat...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
Toro Groundmaster 580-D Lawn Mower (A66285)
Toro Groundmaster...
2018 International HX620 Quint Dump (A62613)
2018 International...
2002 International 9200i Truck (A61307)
2002 International...
(3) Pieces of Poly Pipe (A62679)
(3) Pieces of Poly...
