Question about third function valve
/ Question about third function valve #31
Thank you for the picture. That should work perfectly and is how the logical flow from device to device should be done. If you want the 3rd function permanently in the loop, you could remove the lower set of QDs replacing with a properly threaded coupler as I previously mentioned.
For even more elegance, one could have a custom hose made with a banjo fitting on one end to supply fluid from the loader PB port to the 3erd function and skip a couple of connections, but what you have works.
I think we are done here.
/ Question about third function valve #32
Yup. If the T side of the grapple/3rd is what is supply the backhoe, and the backhoe returns back to the tank than it is plumbed correctly in terms of flow order
Thanks for taking the time to make suggestions and explanations. I appreciate the time and effort you all have given.
Randy
2022 Ford F-450 Liftmoore 5000W 2.5 Ton Crane Service Truck (A59230)
2022 Ford F-450...
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2023 New Holland C327 Two Speed Compact Track Loader Skid Steer (A59228)
2023 New Holland...
