Question about Roundup and discing
/ Question about Roundup and discing #1
HCJtractor
upstate South Carolina, Greenville
Kubota M6800, Massey Ferguson 240
I sprayed my plots with glyphosate and 2,4,D last Monday (6 days ago). Everything is yellowing and looks like I got good coverage. My question is this: we are trying to get our corn and beans planted soon. Would it be unwise to go ahead and disc tomorrow (six days after spraying) or should I wait a little longer? Is the herbicide already taken up by the plant or is there still more activity from the folliage? Will I interupt the process by discing this soon? I expect we are going to have to spray one more time anyway, either right before we plant or just after if our seed are Roundup Ready. But I don't want to disc too early and reduce the spray's effectiveness.
/ Question about Roundup and discing #2
Your plants are dead and just don't know it yet it would be OK to disc especially knowing you are planting RR corn and beans.
Ideal wait time is 10 days.... HCJ Tractor when you spray next time think about adding in some Ammomium Sulfate.
Hard water in the spray tank will reduce Roundup effectiveness. But adding AS alleviates problems caused by hard water.
you to add up to 17 lb. AS to a 100 gallon spray tank.
Good Luck
Michigan Food Plot Specialists.com
/ Question about Roundup and discing #3
Probably ok with waiting 6 days to disc. Glyphosate is translocated within the plant within a few hours of application, just takes a few days to show signs above ground.
On the second application question, if you plant then spray before the crop emerges, you wouldn't need Round-up Ready seeds. Only need RR seeds if planning to spray R-up after the crop is up.
/ Question about Roundup and discing #4
Interested in why you used 2,4-D in addition to the glyphosate. Seems like overkill for the intended purpose. Thanks
/ Question about Roundup and discing #5
It's common practice in MI.
The number one reason I can think of is-weed resistant management.
If memory serves me correctly I believe the mechanism of action is different between the two herbicides and will not only speed up your targeted weed kill but has a more effective killing range
/ Question about Roundup and discing #6
Mixing the 2 is common practice in the deep south also.
/ Question about Roundup and discing #7
I always let the weather dictate in part. If you are not having cooler nights you will prob be OK. I assume since you are wanting to plant beans that the issue of a frost is over well past and your soil temps are in the 60s?
Depending on your equipment size, you may be time ahead waiting another week until everything is dead-dead. If you are using a small light disk it would cut better with everything dead. If using a much heavier Ag disk, you should not have any problems.
/ Question about Roundup and discing #8
If you are disking it up anyway it really doesnt matter. The process of disturbing the soil is going to cause an entire new crop of weeds to germinate that you are going to have to contend with.
/ Question about Roundup and discing #9
I think you are supposed to wait at least 2 weeks after applying 24d to plant.
/ Question about Roundup and discing #10
Thanks koamfps and pjbci.
/ Question about Roundup and discing #12
Not sure on 24d but farmers here generally go at 48hrs with roundup .
/ Question about Roundup and discing #13
I agree. Unless you have a major weed problem to control, not sure why you are spraying and disking twice, especially if it is just a food plot. If you are growing for production, then you probably have serious weeds to control. Disturbing the soil will just allow additional weed seeds to germinate after planting after already spending money on herbicides. Don't spray unless you need to, to reduce the spread of resistant weeds if at all possible.
2016 Ford F-250 Ext. Cab Pickup Truck (A64556)
2016 Ford F-250...
2015 Ford F-150 Pickup Truck (A64556)
2015 Ford F-150...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
Cedar Swing (A65583)
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
