Question about JD 3ph ballast box
/ Question about JD 3ph ballast box #1
Anonymous Poster
Epic Contributor
I've just purchased a new JD 4300 with 430 FEL and 72" mower deck. I opted for the 3ph ballast box rather than the loaded tires because I will be mowing some soft ground. The loader manual indicates that a ballast box filled with Portland Cement weighs 50% more than a ballast box containing concrete.
My question: Isn't concrete merely portland cement, water, sand and gravel? Is the manual suggesting that I only mix portland cement and water and fill the box with this mixture? If so, in what proportions?
I appreciate any information from someone who, unlike me, knows something about concrete.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63689)
2017 Yale GLC050VX...
2011 FREIGHTLINER M2 112 CNG  6X4 T/A DAYCAB TRACTOR (A59912)
2011 FREIGHTLINER...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
2009 Cummins DGFA-5764071 150kW Standby Diesel Generator (A61572)
2009 Cummins...
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
2019 CATERPILLAR 299D2 XHP SKID STEER (A64279)
2019 CATERPILLAR...
