Quad Dump trailer
   / Quad Dump trailer #1
Rio_Grande
Platinum Member
I want a Quad trailer to pull while working in the tighter areas of my property. I relly like the store bought ones that have the plastic tubs but the thicker sturdier tube are uber expensive for what a guy is getting.
So,,, I am thinking about building one they are stupid simple and there is nothing to them except that plastic tub,,,,,,, I would like to have that, but cant if making it myself so I am looking for some ideas on how to make the bed. I was orignaly thinking just wood deck with wood sides but that would make it heavy...
Any ideas? Examples? Just looking for a direction beyond the simple stuff.
   / Quad Dump trailer #2
I'm looking forward to the build. I made a double axle dump trailer a few years back for my lawn mower. I made mine with a metal frame a wood bottom and sides. It is heavy, but it doesn't seem to slow me down. I can still run it up a ramp into my truck by myself, and I'm no Heman.
   / Quad Dump trailer
I looked at your build last night, Well done.
   / Quad Dump trailer #4
Thanks. It's still going strong.
I wonder if you could rig an old wheel barrow tub for your trialer. That would be quick and easy.
   / Quad Dump trailer #5
I have seen replacement wheelbarrow tubs for sale in home improvement stores. Both plastic and metal ones, and they are available in various sizes. It might be cheaper to buy a complete wheelbarrow. Perhaps you will have uses for the wheels later.
I once had a notion to build a tandem trailer with two wheelbarrow tubs mounted on it, that dumped off the side, so the tubs were mounted one in front of the other. Maybe have handles that could retract, that when extended would look like the normal wheelbarrow handle under the tub. Each tub dumps independently.
   / Quad Dump trailer #6
What about using a 100 gallon tank with the top cut out? A 200gallon oil tank would carry about a cubic yard of somethin'....
   / Quad Dump trailer
Pat I thought about that, cutting a 250 gal fuel oil drum, one of the oblong ones. Would have to get the edges really smooth,, gotta haul the younguns :)
That is actually the closest Idea I have so far,,,, Short of a wood bed,,,
   / Quad Dump trailer
Mentioned it to the wife,, said I aint putting her children in a metal deck trailer,,, She ruins everything,,, LOL
   / Quad Dump trailer #9
The other option is a food grade 55 gallon drum. The ones we get salad oil in at work are lined with a plastic coating of some sort. Might convince the Mrs.
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
FORD 8630 TRACTOR (A60430)
FORD 8630 TRACTOR...
