QD Dust Caps?
/ QD Dust Caps? #1
n8wrl
Rural SC
Kubota L5030 HST
Try as I may I have not been able to find dust caps for 3/8" quick disconnects! My WR Long kit came with 3/8" and all I can find are 1/2" or bigger. Any tips on where these can be found?
Thanks!
-Brian
/ QD Dust Caps? #2
Thanks!
-Brian
Brian,
Here is where I ordered Dust caps , Dust Plugs, and Nylon Abrasion Sleeve to bundle my hoses together for a clean install.
Dust caps/plugs
ISO 7241-1 Series A
You have to look at the Part # for the Quick Disconnects, and match the # for the 3/8" QD to the Part # for the Plug/Cap. Or just give them a call.
Protective Hose Wraps
Hose Protection
Hope this Helps
Dan
/ QD Dust Caps?
Thank you! Shortly after posting I stumbled across DiscountHydraulicHose. I found what I needed, but they do have a minimum order. Oh well - stock up on other stuff.
Thanks again!
-Brian
/ QD Dust Caps? #4
TSC has some caps.. I'm not sure what size..
Soundguy
/ QD Dust Caps? #5
Any JD dealer should have some. They come with the small JD loaders. Also check with Agri-Supply in SC.
/ QD Dust Caps? #6
Thanks!
-Brian
Try TractorSmart home page
I ordered a set of 1/4" and noticed that they also had 3/8".
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
iDrive TDS-2010H...
(INOP) 1991 GMC TOPKICK DUMP TRUCK (A59823)
(INOP) 1991 GMC...
20in Digging Tooth Bucket Excavator Attachment (A60352)
20in Digging Tooth...
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
