Putting Water Hydrants In
/ Putting Water Hydrants In
Here is where I rounded the back of the house. It was steep here so I had to be careful with support placement and how fast and high I moved the bucket. Turned out just like I wanted it to.
This is the last one for now. You can see with the placement of the tractor that I am making my way into the backyard at the south of the house. I'll have a few more obstacles here like our septic line and underground cable. Should be interesting! I'm feeling like Eddie Walker digging this much waterline trench! (That's a compliment Eddie btw /forums/images/graemlins/smile.gif ).
At this point I am at about 300' of 6' deep trench. More to come next week.
/ Putting Water Hydrants In #23
Tim,
Looks great. I am jealous, would love to have a back hoe. Not sure what the rules are in your area, but in Michigan they try to make us use blow out fittings on our hydrants. I leave them set up with the blow out fittings on them for inspection then I set them up so they drain back into the ground when I shut off the valve. I surround the base of the valve in a bunch of pea gravel wrapped in landscape cloth to make sure that there is plenty of room for the hydrant to drain when shut off.
Your work looks like you are a pro. Thanks for sharing your photos.
Farwell
Farwell, thanks for the compliments! It means a lot since I am just learning on the hoe. The setup with the rock and the fabric as you described is pretty much how I am going to go. I will also be equipping these with vacuum breakers to prevent contamination through the hose. I'll be using 6' bury Y1 Iowa hydrants and 1" pipe. They should let out 46 gallon per minute!! I told my wife not to drink water directly from them as her cheeks would explode /forums/images/graemlins/smile.gif.
Having lots of fun with this project! Also, this is the first time I used earplugs while I was on the tractor and that's how I am going to do it from now on. Really makes a difference! My wife says I don't shout at her now when I'm done like I used to. /forums/images/graemlins/smile.gif
Thought this might be helpful as the project moves along. This is the type of hydrant I am putting in. It's the Y1 6ft bury:
hydrant specs
Made a little progress on this project last weekend. Here is a shot of the trench coming round the back of the house. The hose over the trench is the temporary water lines I used this summer. They're a big reason for the hydrant install /forums/images/graemlins/smile.gif.
The water line will need to go under my septic line so I have some careful digging to do in the next photos. I ran a line to estimate where the underground sewage pipe is buried.
After attempting to dig dry rock-hard clay I decide to get back on the hoe and take tiny scrapings and then have another shot with the shovel. The first scoop I take produces a white shaving! In terror I jump off the hoe to be pleasantly suprised that I just peeled a tiny shaving off the pipe with no real damage! Man was I lucky! Here is a shot of the exposed pipe next to the shovel.
Here is a non obstructed view of the exposed pipe.
After finding the pipe my next job is to position the hoe so I can dig underneath it without damaging it. The pipe was around 19" underground, and my waterline will be 6' down so I have some clearance room here. The hard part was positioning the hoe to straddle the trench so I could get the support arms down.
I trenched about 15' more after this when my pto pump started leaking. I've had the same problem before with the gear oil coming out so I knew if I didn't stop I might have a backhoe with the arm stuck in the ground and no way to get it to the shop. This is the first hoe that my dealer has sold so they are being very helpful but at the same time learning from my setup. I'll leave you with this picture of me with a face of relief that I at least didn't have to do emergency plumbing repair that day! /forums/images/graemlins/smile.gif I should have been done with this project that day but I'm not sweating it. Lots of time before the ground freezes!
/ Putting Water Hydrants In #31
Tim, is your pump leaking hydraulic fluid or is it leaking gear oil?? (Like my first pump did///..) BobG in VA
BobG,
Its the gear oil from the PTO pump. As far as I can tell the hydraulic side is fine. I became alarmed when I heard some strange noise coming from the pump and it took a quart of gear oil!
Looks like it might be leaking from the glass indicator on the side or below. This is my second pump so it might be an indication that something else is wrong. Not sure yet.
Are you saying your pump leaked gear oil as well? I was given one of those "That's never happened before" responses and this is the second time for me.
It's the Itallian pump sold by Bradco.
/ Putting Water Hydrants In #33
Yep, my first one blew out the seal on the gear oil (seal where the PTO shaft goes in. Come to find out that the pump they sent was the wrong one anyway. I've got about 3 hours on the 511 and so far so good. Mine is the Italian pump also. I think its happened more than once. .....BobG in VA. PS I changed the hydraulic filter on the 511 (I may have mentioned this to you before), but I lost about a gallon of hyd fluid with the changeover. BobG in VA
That's nothing! I lost 2 gallons!! The air turned blue for a bit. when I was trying to get that other filter on /forums/images/graemlins/smile.gif. Hey, can you tell me what the numbers are on your pump sometime? I think mine says MU21 and 1.3.8 for a ratio. Is that what you have? The next time I have that thing off I'll have to take some pictures of it for reference since you can't see anything on it when it's installed. The only way I knew it was low was to remove the side drain plug and add to the top. I couldn't see the glass when it was installed. I was really suprised when I kept adding fluid and nothing came out the side drain!
I am relieved that I am not the only one going through this. Do you think yours is good to go now? Anything change besides replacing the pump? This will be my 3rd pump when I get it back. They picked up the tractor yesterday so my hydrant project is on hold for a bit...
/ Putting Water Hydrants In #35
<font color="blue"> The pipe was around 19" underground, and my waterline will be 6' down so I have some clearance room here. </font>
And I thought I was going deep at 2' down. Of course around here nothing freezes below 6".
I've got all of mine done except the final connection at the pump house (and a "few" rocks to pick up /forums/images/graemlins/frown.gif)
Anybody want to buy several hundred feet of hose?
2' sure would have been nice, but it sure gets cold here in Iowa! Kind of hard to imagine right now with it still in the upper 80's for September. That's about 10degrees above normal.
Gas prices and shortages made us reconsider our trip to the twin cities over labor day so I was able to make more progress on the hydrants.
My tractor dealer was able to honor my time requirements and get my tractor back with the PTO pump fixed and also fix some minor warranty items, (hazard switch, air clog sensor). The pto pump just needed a new level see through indicator on the side as the one that was in there apparently had its threads stripped at the factory.
Okay, so back to the hydrants. I had to fix a cave in and correct some high points in the trench. Here is some of the remaining trench digging.
And here is the final stretch. I had to make all the corners so I would miss the septic and other obstacles.
Only casualty was the electrical line to the livestock building. I will be fixing that tonight before filling in the last part of the trench.
After I finished the digging I began the install for the hydrants. Here is the north hydrant shortly after it was set.
You can see the pea gravel at the bottom if you look closely.
Here it is with the garden mesh to keep the silt out.
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
2008 Chrysler Sebring Convertible (A62679)
2008 Chrysler...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
1991 Ford F600 Fuel Truck, VIN # 1FDNK64P0MVA37029 (A65563)
1991 Ford F600...
