Putting Split Rail Fence in
   / Putting Split Rail Fence in #11
I put in 100' of box store purchased 2 rail fence last summer. I used the method described by beenthere and it worked well. It is rustic looking, but that is what I wanted. I did put the post down 3'.
Digging the post holes is the only hard part of the process.
   / Putting Split Rail Fence in #12
Here's about 450' of two-rail I put in a few years back. It replaced original similar fence but offset by 3' to one side of the old fence, used new posts but re-used all the 30 year old rails by cutting 6" off each end of the original 10' rails and spacing at 9' instead. 3' deep holes not really needed for this type fence, this is not livestock fencing, just red cedar "landscape" fence. 24-28" with a bit of gravel in the bottom for drainage and leveling post tops is plenty deep if posts are well tamped. All hand dug, post/rails fitted one hole at a time, no tractor needed. In fact, I think a tractor & PTO digger would just have been in the way and more trouble than it would be worth. This is nice pleasant summer upper-body exercise. Not that hard to do, I was 63 when I put this in. Forget concrete and deep holes, around here natural cedar posts will eventually rot out at ground level no matter how you set them, just plan on replacing the posts every 15 years or so. Or use that phony-looking white plastic fake stuff you see everywhere. :laughing:
   / Putting Split Rail Fence in #14
I was not planning on doing the cutting, but buying the posts w/ the slots in them. Commonly available for $9 a post or so.
Well I learnt something today :cool: as I did not know you could buy fencing like that, with the notching already done. Guess the only tricky part from looking at the pics from picker77 is you have to make darn sure of the post placement. :)
   / Putting Split Rail Fence in #15
Prices have gone up quite a bit in the the last 5 or 6 years, but here's what a local supplier in my area sells, others are fairly competitive. Cedar Split Rail Fence - Lumber 2 Home and Ranch, Oklahoma City. You generally only have to buy rails once, though, since except for a little eventual dry rot on the ends they are re-usable with new posts. I just trimmed the ends off on my old rails with a Sawzall and cut new tenons with a broad chisel, easy quick to do. In fact, any repair to a split rail fence is easy and quick to do, that's one of the things I like about them. Figure about $3 a foot for materials for a new two-rail fence at current prices, about a dollar a foot to replace just the posts. Get a few extra posts and rails when you order, because (a) you'll break a rail on rare occasion and (b) there's no guarantee the holes will be drilled in exactly the same places if you go down to buy a replacement post in the future. Replacement posts or rails will weather out in one season to the same natural grey as the existing fence. We had a neighbor's horse get into our place and walk through the fence once, had to replace a couple of rails but the posts held up just fine.
I personally prefer the look of 2-rail over 3-rail for some reason, which is good because it's cheaper. Tip: Measure from the ground to your crotch and set the posts so you can tip-toe over the top rail without having to put any weight on the rail. This worked for me (I'm 6'4") but didn't work so well for the wife, lol. Mowing is no problem, a quick run up and back with a weedeater once a month in the summer keeps it looking nice so the city tourists can ooh and aaah as they do their Sunday country drives.
   / Putting Split Rail Fence in #16
Good observation Mousefield. And it is the reason for putting the next post hole in one at a time if a tight connection of the rails is desired.
picker77's fence shows he put in a lot of care and planning along with the hard work. Very neat and tidy fence to add to the attractive landscape. Makes for a warm feeling for everyone driving down that lane/road. :)
   / Putting Split Rail Fence in #17
Want to put in a 300' split rail fence in. I was planning to dig about 2 feet deep w/ a PHD, tamp & put down some gravel. Drop post in and back fill w/ dirt. Don't really know how rocky the soil is (I'm in western PA, just east of Pittsburgh). Want to start next month (January). Other than putting up w/ the cold, are there any issues w/ doing this in the dead of winter?
Am I oversimplifying, or is that all that there is to it?
I am presently in the middle of building a 3 rail entrance at the front of the property. I have completed drilling out all 14 6"x6" PT timbers x 10' .Yes they are long but only 4' 8" are going in the ground and the rest has a fancy top. I have pics of the posts but they still in the camera. So I borrowed a pic of what the gate is going to look like. The first side rails are rough drilled out and laying on the bench. i fabed up rollers and used a 1 1/2 " spade bit to drill through using a bench top drill press. As the slots are on angles it was not a 90 degree job. The job went slow but the results are great. Before the ground froze up I cut and chipper ( 4 ) 30 ' trees and used the BH to remove 2 of the stumps.
Craig Clayton
   / Putting Split Rail Fence in #18
Craig
What is the pic showing?
Your fence?
   / Putting Split Rail Fence in #19
To beenthere
The pic is of an English Estate Hook style wooden gate.
It all started when the Postal Service informed me that my mail box needed to be moved back 12". So I complied.
Then I looked at the gate entrance which lead to the afore mentioned comments. As the gate is laying on the assembly bench this is the best that I can do until spring.
I am planning on uniting 3 cultures using a Americian 3 Rail fence ,with a English Estate gate built by a Canadian.
This is representive of our border so it should work.
Craig Clayton
   / Putting Split Rail Fence in #20
Up here the fence would shift the first spring. We've got heavy clay soil and a pretty brutal freeze/thaw cycle. Even a 3 foot white picket fence that will never have more stress than the occasional cat sitting on it gets 3 foot deep holes when I build it. I don't like warranty calls.
I love the plastic stuff. It's so neat and clean when you rip it out and haul it the dump so you can build a wooden fence.:thumbsup:
I try to use pressure treated wood whenever possible. I find the cedar we get here is so soft that it doesn't so much rot as abrade away. I've got pressure treated posts in my backyard that are 20 years old and in near-perfect condition, but I see cedar post fail regularly between 5 and 7 years.
I do this for money. Power equipment is a must because you need to get done and move on to the next job, especially since you only have from May to October to make a living. I have a hand auger and some skinny shovels, but they rarely make it out of the back of the truck.
That's a nice gate.
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2018 Dodge Durango Multipurpose Vehicle (MPV), 175,918 Miles, Third-Row Seating (A56438)
2018 Dodge Durango...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Unverferth 25' Head Cart (A59814)
Unverferth 25'...
1997 PETERBILT 387 CAB CHASSIS TRUCK (A59575)
1997 PETERBILT 387...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
