Put toggle switches in my work lights
   / Put toggle switches in my work lights #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I bought a pair of headlight floods with switches built in so I could avoid the hassle of running wires back and forth to the dash but the switches that came with the lights were really poor quality and failed almost immediately. So I decided to drill the holes somewhat offset from the first set of smaller holes (for clearance) and put in a couple of switches I had. Note--I have the rubber toggle switch covers but didn't put them on yet. To get the switch to fit the hole exactly, I used a cheap harbor freight reamer to size the hole.
it worked great. The lights run off a hot wire that I fused and the lights bolt to the weight bracket on my B7800 and help me mow the grass at dusk. Plus, I can flick the lights on in the back barn at night without having the tractor key with me.
Maybe others have done this and this is old news but it worked for me and is a simple solution to finding lights with a built-in switch.
Here's a link to toggle switch rubber covers at The Surplus Center
http://www.surpluscenter.com/item.asp?item=11-3250&catname=
   / Put toggle switches in my work lights #2
Good repair. I guess I'd want to add some of those rubber toggle switch boots to help keep the water out of the switches.
   / Put toggle switches in my work lights #5
Never seen a switch put in a light like that. Pretty slick.
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
UNUSED FUTURE...
SUV (A59231)
SUV (A59231)
1996 Timpte 46ft Hopper (A56436)
1996 Timpte 46ft...
Kubota RTV X900 (A53317)
Kubota RTV X900...
