Put PT422 on Side (Kinda)
/ Put PT422 on Side (Kinda) #41
>>>>My problem is I don't have time for anything<<<<
I heard that. Between extending my deck, finishing my downstairs basement, wood working, things that need done around the house. Leaves little time to do PT related things beyond landscaping outside. Not to mention social functions with the wife. As the commercial say's, Life comes at you fast. /forums/images/graemlins/laugh.gif
/ Put PT422 on Side (Kinda) #42
/ Put PT422 on Side (Kinda) #43
There are taper shaft hubs out that have a brake drum and band and is activated by a cable hooked up to the emergency brake lever. My Dixie Chopper has this arrangement, and the hydraulic motor is similar to the PT wheel motor.
Maybe a go-cart disc brake setup would work.
/ Put PT422 on Side (Kinda) #44
/ Put PT422 on Side (Kinda) #45
Your right, it’s very easy to develop a false confidence with this machine rolling along at 8 mile an hour. When something like J.J. mentioned does happen, you realize 1200 pounds rolling down hill out of control is not something to be taken lightly. The PT is not a toy.
When I use any kind of machinery be it hand saws, chain saws or just a simple wood lathe. I always try to envision what might cause an accident, and eliminate and hazards. Very good advice. /forums/images/graemlins/shocked.gif
/ Put PT422 on Side (Kinda) #46
/ Put PT422 on Side (Kinda) #47
This is a picture of my grab handles
/ Put PT422 on Side (Kinda) #48
/ Put PT422 on Side (Kinda) #49
This is a picture of the upper grab handles.
/ Put PT422 on Side (Kinda) #50
/ Put PT422 on Side (Kinda) #51
JJ,
Your PT must've been built before they had tubing benders in Tazewell... /forums/images/graemlins/laugh.gif
Those angular braces would certainly strengthen it though... not counting making handy grab handles...
/ Put PT422 on Side (Kinda) #52
JJ,
/ Put PT422 on Side (Kinda) #53
My 1445 is an early 90 model. PT has very data on this machine. It is a 45 hp gas engine with a radiator, and smooth and quite. If you can look at some of my earlier pictures, you can see the engine compartment.
/ Put PT422 on Side (Kinda) #54
/ Put PT422 on Side (Kinda) #55
Nice work J.J. I will defiantly take your advice, as I don't have a welder, I will look for a U bolt setup, or a large over size cable clamp style to rig my grab handles with. /forums/images/graemlins/ooo.gif
/ Put PT422 on Side (Kinda) #56
/ Put PT422 on Side (Kinda) #57
</font><font color="blue" class="small">( My 1445 is an early 90 model. PT has very data on this machine. It is a 45 hp gas engine with a radiator, and smooth and quite. If you can look at some of my earlier pictures, you can see the engine compartment. )</font>
I've looked at your pictures -- I was just teasing!
/forums/images/graemlins/blush.gif
I wish mine had a quieter, water-cooled engine, either gas or especially diesel. But, I wouldn't want to go back to the older manual 3-pt attachment method, though...
/ Put PT422 on Side (Kinda) #58
I like the hammer holder too. Can we get a better picture of it.
Bob Rip
Bob Rip
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
Towable Pump (A64553)
2015 Volvo L30GS (A62180)
2015 Volvo L30GS...
