Put my Chains on Today
/ Put my Chains on Today #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I put the chains on today. This type chain is supposed to be sloppy so it can walk around the tire. You are supposed to be able to fit your balled up fist between the side chain and the tire sidewall when they are right. But after 8 years mine were getting really to sloppy. I had to cut off 2 links of length (circumference) to get them back where they should be.
Out of curiosity I wondered how much wear that was. If each link had 10 thousands (.010) worn off at each end it would account for little more than 2 links worth of stretch around the tire circumference. Seems reasonable for 8 years I guess.
/ Put my Chains on Today #2
Looks good for 8 years old. My duo-grips have worn far more than that.
/ Put my Chains on Today #3
I put mine on today as well. Much nicer messing with them with the temps in the 50's and the sun shining rather than temps in the 20's and starting to snow like I did last year.
/ Put my Chains on Today #4
My chains look about identical to yours and I had the same brand of angle grinder working on my chains the other day. Even the grinder takes a while to cut them. Mine have loosened too but for this winter at least four bungees on each wheel fixed them up.
The 2 link combined wear is interesting. My chains are six years old, my R4 tires are wearing down too. The offset "C" shaped links used to tie the chain ends together have gotten loose enough that I dropped one last winter and the winter before. I switched to those screw together cable links this year. I used one last year after dropping the C link and it held up. I found the C link after the snow melted about where I thought it must be.
/ Put my Chains on Today #5
:thumbsup: A serious set of chains! Put mine on a few days ago. Instructions say "loose fit" but tight fit works best for tractor with small clearance.
You put them on the front also, or just the back?
I just have them on the back. I use the tractor mostly in the woods. With a load on the 3ph the front end tends to be light so it can be hard to turn especially when you have a 35 foot log rudder on the back trying to hold you straight. Sometimes I see those little front tires turning in the snow trying to get purchase to make a turn and they just can't. But the steering brakes work great (I use them a lot) and turns aren't a problem when using them. I get enough pulling traction with the rear chains and the diff lock (when needed). However, I believe front chains would be beneficial but my tractor dealer advised me not to use them in the woods where the ground is rough. He explained it this way. The front end drive train is relatively weak, made with small components. If you are plowing a driveway on smooth ground front chains would be OK because the chained front tires will not loose traction very often and there will be no strong jerky forces on the weak front drive train. But if on rough ground in the woods pulling a heavy load a front tire will lose traction and start to spin every time you go over a depression or bump and then the spinning chained tire will suddenly grab putting strong jerky forces on the little drive train. Do this enough times and something will break. So because of this advise I have not chained the front. Some have and w/o trouble. Some have and had big trouble. I don't want to chance it.
/ Put my Chains on Today #8
It is the time of year.... I put my chains on Tuesday and move snow...
Had to move this first snow of the season.....
Then wait until today for the township snow plow to come around before I could get out to the county road..
Take care...
/ Put my Chains on Today #9
That sounds like good advice.
/ Put my Chains on Today #10
Very nice setup, Gordon, I see you have R1's on the back.:thumbsup:
Is that the plow you use on your tractor.
/ Put my Chains on Today #11
I put my chains on yesterday, woke up to 3" of snow today and still snowing!! :eek: I run front and rear chains, strictly for moving snow.
No that is a 9 footer I use on my One Ton. I don't normally plow with the tractor but spend a lot of time push banks back with it.
/ Put my Chains on Today #13
I am soooo happy not to need chains anymore now that I have a 4WD tractor with turf tires!! (don't go into woods much) Thanks to TBN counseling. Then again, I'm not retired yet and don't have the time to futz as much as some here. ;)
Time to change avatar to winter, I guess. 12.5 inches snow here on Monday.
/ Put my Chains on Today #14
Interesting - I'll buy that. I've only been chaining the front for the last 5 years for snowblowing my drive. No tire spin involved anywhere. I'd like to chain the rears, but given how much hassle putting on the fronts is, I can't imagine ever being able to actually get them on - never even tried. Rear 2-link ladders still brand new in the box - $400 down the crapper.
/ Put my Chains on Today #15
Rear chains are easy once you master them. I have probably installed chains on 2 dozen different machines over the last 15 years.
/ Put my Chains on Today #16
I won't say it is as easy as falling off a log, but it is not so bad as to leave them in the box.. There are as many methods as there are people. But this is what I did last Saturday. Get out your hydraulic floor jack, and jack up the center of your tractor, taking both rear tires off of the ground about 2 inches. Lay out the chains to the rear of the tires the way they will go, with the bottom of the chains on the ground. Drag them up to hook on the tire and hold the end on the tire with one hand while you rotate the tire forward with the other.. This is not all that hard to do. As the chains hook on the tire and start to go down the front side of the rotating tire (by the way the other tire is rotating in the other direction due to differential action). The weight of the chains on the tire want to keep the rotation going, so be prepared to stop the tire before it goes too far or it will just dump the chains on the ground in front of the tire.:shocked:
Prepare a "reacher stick" I made one from a piece of PVC pipe with a hook on the end. Position yourself at the back of the tire with the chain balanced and draped over the tire. Now rotate a bit more so that the front of the chain starts to pile up on the ground in front of the tire. Reach under the tire with the stick with a hook and hook the chain and drag it under the tire. Pull it up a bit onto the rear of the tire, to get the center and side hooks hooked up. Continue to tighten as needed and straighten out the chain as you rotate the tire through several rotations. Repeat for other side.. You are now hooked up. Not a whole lot of cursing needed, and no driving of tractor over chains etc. Not a lot of hassle. and if you have garage floor to do this on, even better.
Again there are many other ways to accomplish this, but this is what I did. There you go, free advice!.. and worth every cent you paid for it! :)
/ Put my Chains on Today #17
Jay: I bet you could sell those chains, what size and price?
/ Put my Chains on Today #18
My favorite kind of pic.
/ Put my Chains on Today #19
My experience with front chains while in the woods is way different than your guy explains. First, our loads like what is in your pic, put most of the weight on the rear of the machine. I use front tire assist mostly for when the tractor is going through deep snow and mostly on the return. I have never seen the front tires "spin and grab" because things are happening in slow motion when skidding with not enough rotational speed for front tires to "lock in" so to speak traction wise. I have seen front tires spin with chains while doing what your guy is saying is all right to use. That is: when plowing snow. Especially when your tractor is reaching it's "push" limit and the fronts begin to spin because of the snow load.
I agree the front is weaker than the back but I would need another reason not to use front chains such as "not spinning" as spinning is really a relinquishing of load and sort of acts as a like a safety valve. Chains might provide too much traction for the fronts putting strain on the front components when it is safer for them to "spin" and chains preventing that. The thing I like about front chains the most is the protection they give the tires in rocky, ground obstructed terrain.
/ Put my Chains on Today #20
I think front chains are one of those things that can work, but you must be careful with them. You could damage the front axle with chains, then again, if you do not have front chains, and say the tractor slides into a car....
