Purging a Tank For Cutting/Welding
   / Purging a Tank For Cutting/Welding #11
The four open bungs in themselves are not a for sure means of ventilating out any flammable gases I suspect.
No, I was just wondering if it constituted enough of an opening to vent an explosion without ripping the tank apart. So I get more of a woosh and not a boom!
   / Purging a Tank For Cutting/Welding #13
I've been around several oil/propane tanks that were purged with exhaust from truck. Just let idled for about 15 minutes on a 275 gal tank. I've personally done a 100 lb propane tank that way, and I'm still here! Thing I did differently was while exhaust was still going in, I moved a lite fireplace match to see if fumes would ignite. Main thing is be careful. Idea of CO2 fire extinguisher or if you mig, what about shielding gas to purge tank?
   / Purging a Tank For Cutting/Welding #14
I don't want to leave this thing around for someone else to have to clean up some day, but what am I supposed to do with the sludge? I can burn some on a brush pile, but not that much.
Your good intentions are commendable. Could you pave the road to H*** with the stuff? How about cutting a hand-hole large enough to extract a sample to see whether and how obnoxiously it will burn.
Surreptitious burning may be the "best" practicable method of disposal.
It would help to have someone discharge the C02. There is no one else here at the moment, and would I really want to endanger someone else? Thinking about later this afternoon when it's cooler.
I wish, their was a junk part of the tank, I could just cut a quick big hole to settle my nerves.
Seriously, if it was just for needing the tank to store some manure, I would forget this, and just dump some on the ground. But this toxic mess needs to be addressed, sooner or later.
Thre is a name on it. I should call them and say I found this in the local stream and the fish and game people would like to have a word with them.lol Or they could just come and pick it up please.
   / Purging a Tank For Cutting/Welding #16
I want to cut it in two with a plasma torch . . .
If you have a plasma torch you likely have the means to repair any hole/panel you make.
HOWEVER If the plasma uses compressed air to blow the plasma away you would be replacing the O2 you had worked to remove.
Placed the tank into position away from buildings, in the hot sun. I don't like it! Smells too fresh inside. Nothing like old oil or stale gas. And it's been here fifteen or so years. I would swear there was/is tar in there. It's not impossible that I wasn't given the correct information about old oil storage. Maybe I made some assumptions too.
So how dangerous is tar?
I'd like to say funny, but this is one of the first things I came accross.
THE EXPLOSIVE DANGER OF THE ASPHALT FUMES – A REMINDER AFTER THE ASPHALT TANK EXPLOSION AT LA CROSSE, WISCONSIN - Metropolitan Engineering Consulting and Forensics
Now, I'm really spooked! The prospect of not just being blown up but tar and feathered too.
Sitting here wondering what to do? It would be a stupid way to die.
I wonder if a sawzall would be better? I mean, you can't beat the ignition capabilty of a plasma torch. Possibly the worst tool, next to a torch.
Sounds lame, but I think I might try a jig saw.
Material appears to be about 3/16" steel. Got about 1/2" with a jig saw using a brand new WALTER blade, and figured that wasn't going to cut it, no pun intended.
Wouldn't 3/16" make a fine bomb though! lol
I noticed that the bungs appear to be five inch, but have nylon bushings to bring that down to four inch. Is that so the bungs don't rust in or is that plastic supposed to melt in a fire allowing the contents to boil off?
   / Purging a Tank For Cutting/Welding #19
Thanks. I didn't specifically see anything mentioning using engine exhaust. Is it unacceptible practice because it is so undefined? How much is enough? What RPM, for how long?
I am still curious if it could blow up with four large bungs open?
We have hazardous waste collection days, but the depositry is far away and I am totally oblivious to local news and events as it's ALL Left oriented media in this country, so I don't listen or watch.
You seem internet savvy, so why don't you just look up hazardous waste collection in your area rather than relying on a public service announcement to happen to coincide with a time you just might be watching wheel of fortune?
Spoke with a friend that has been repairing other peoples stuff in this rural/farm environment for fifty years. Says if it didn't have gas in it, just take the plasma torch to it. I stuck the leaf blower in there for a moment, discharged the CO 2 extinguisher a little and put the torch to it. I really didn't know if I was experiencing my last few seconds on earth! Well I got it cut in two and I'm still here. Thanks all for input.
Worst part was the paint (no doubt lead based) and labels I had to cut through. Leather gloves caught on fire and so wrapped glove in water soaked rag, which also quickly caught fire too from the intense heat.
More pictures to follow.
Now another problem. I was going to weld feet onto the bung plugs and make a fire in the top portion to get rid of any residual oil. But those nylon bushings in the bung holes will melt!
(2) CUTTLER HAMMER 200 AMP DISCONNECT (A52708)
(2) CUTTLER HAMMER...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
Volvo L306 (A57148)
Volvo L306 (A57148)
2022 Horizon (A55973)
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
2020 MACK P164T (A58214)
2020 MACK P164T...
