pump issue
/ pump issue #1
jasonhydraulic
massey 12
i built a loader for my vintage 12 hp garden tractor using an 11 gpm 2 stage wood splitter hydraulic pump and it worked great this year i decided to add power steering using a priority diverter valve set at 3 gpm to the steering so the problem i'm having is the steering works as it should but the loader is now insanely slow so the question is do i just need a bigger pump or is there something else i can do to speed up the loader
/ pump issue #2
You're using the wrong pump for that application. The 2 stage pump is most likely kicking out to low flow/high pressure when the flow divider is installed.
/ pump issue
what would you recomend for a pump it's only a 12 horse power tractor
/ pump issue #4
I would say something around the 0.3ci to 0.4ci. It will never be as fast as it was with the 2 stage pump, but it should match the hp of the engine. About 5 GPM at 2000 PSI. Some of that will go to the steering though-
/ pump issue
ok thanks i think i'm going to try a little bigger pump and repower it with a 20 hp engine if i have to
/ pump issue #6
New Quick Attach Power Spreader (A65579)
New Quick Attach...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
Landhonor SGB-11-72W, 72" Grapple Bucket  (A62679)
Landhonor...
New/Unused Receiver Hitch Ripper (A65583)
New/Unused...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
2022 Caterpillar 299D3 (A64126)
2022 Caterpillar...
