pump issue
/ pump issue #1
jasonhydraulic
massey 12
i built a loader for my vintage 12 hp garden tractor using an 11 gpm 2 stage wood splitter hydraulic pump and it worked great this year i decided to add power steering using a priority diverter valve set at 3 gpm to the steering so the problem i'm having is the steering works as it should but the loader is now insanely slow so the question is do i just need a bigger pump or is there something else i can do to speed up the loader
/ pump issue #2
You're using the wrong pump for that application. The 2 stage pump is most likely kicking out to low flow/high pressure when the flow divider is installed.
/ pump issue
what would you recomend for a pump it's only a 12 horse power tractor
/ pump issue #4
I would say something around the 0.3ci to 0.4ci. It will never be as fast as it was with the 2 stage pump, but it should match the hp of the engine. About 5 GPM at 2000 PSI. Some of that will go to the steering though-
/ pump issue
ok thanks i think i'm going to try a little bigger pump and repower it with a 20 hp engine if i have to
/ pump issue #6
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
2022 HAULMARK 14' T/A ENCLOSED TRAILER (A65643)
2022 HAULMARK 14'...
