pump hook up
/ pump hook up #1
gilbertson
Suffolk, VA
Satoh
Can anyone tell me how to hook up the pump in the picture, it has 3 outlets and looks like a vent. I started making the mounting brackets for the motor with 1/2" plate, welded together, drilled and bored a 4 1/2 hole.
Thanks
Vern
/ pump hook up #2
Thanks
Vern
You really have a lot of trust in this forum :D ....but I do think you need to provide some more detailed info about whats going on....
Do you have an ID for the pump?
What application are you planning to use it on??
etc etc..
/ pump hook up
This is the hydrostatic drive from a Ryan DGA 30-06 riding aerator, it consist of left and right 540075 wheel motors and a 547906 variable displacement hydrostat pump.
Pump:
Sauer Sundstrand
.91 Cubic Inch Variable Displacement
CCW
A-93-15-42961
15-2196
Motors:
Parker (Nichols Motor Division)
16.4 Cubic Inch Displacement
(RH motor)114A-189-YS-0-05 F2 54
(LH motor)114A-189-YS-0-05 F2 55
Manual drum brakes
5 bolt on 4 ス bolt pattern
I am putting this on my backhoe.
Thanks, Vern
/ pump hook up #4
gilbertson,
top left hose barb is suction from reservoir(this pump has built in charge pump under front cover) make sure rotation is correct (it can be changed), two ports on far right (end cover)are pressure ports going to hyd motor and remaining port on case housing is case drain returning back to reservoir tank unrestricted.
Good luck on your project,
Bill:)
2022 EZ-GO ELITE...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2019 KENWORTH T370 FLATBED TRUCK (A65643)
2019 KENWORTH T370...
1999 GROVE MZ66DXT TELESCOPIC BOOM LIFT (A65053)
1999 GROVE MZ66DXT...
KUBOTA SVL97-2 (A65643)
KUBOTA SVL97-2...
New/Unused Landhonor 78in Rock Bucket with Teeth (A65583)
New/Unused...
