pump hook up
/ pump hook up #1
gilbertson
Member
Suffolk, VA
Satoh
Can anyone tell me how to hook up the pump in the picture, it has 3 outlets and looks like a vent. I started making the mounting brackets for the motor with 1/2" plate, welded together, drilled and bored a 4 1/2 hole.
Thanks
Vern
/ pump hook up #2
Thanks
Vern
You really have a lot of trust in this forum :D ....but I do think you need to provide some more detailed info about whats going on....
Do you have an ID for the pump?
What application are you planning to use it on??
etc etc..
/ pump hook up
This is the hydrostatic drive from a Ryan DGA 30-06 riding aerator, it consist of left and right 540075 wheel motors and a 547906 variable displacement hydrostat pump.
Pump:
Sauer Sundstrand
.91 Cubic Inch Variable Displacement
CCW
A-93-15-42961
15-2196
Motors:
Parker (Nichols Motor Division)
16.4 Cubic Inch Displacement
(RH motor)114A-189-YS-0-05 F2 54
(LH motor)114A-189-YS-0-05 F2 55
Manual drum brakes
5 bolt on 4 ス bolt pattern
I am putting this on my backhoe.
Thanks, Vern
/ pump hook up #4
gilbertson,
top left hose barb is suction from reservoir(this pump has built in charge pump under front cover) make sure rotation is correct (it can be changed), two ports on far right (end cover)are pressure ports going to hyd motor and remaining port on case housing is case drain returning back to reservoir tank unrestricted.
Good luck on your project,
Bill:)
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2014 Kawasaki 70Z7 Articulated Wheel Loader (A64553)
2014 Kawasaki 70Z7...
Skid Steer Finish Mower (A65640)
Skid Steer Finish...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
100-gallon L-shaped Split Fuel Tank (A66408)
100-gallon...
