Pulverizer
/ Pulverizer #1
toxic
PEI, Canada
Kubota m7060 , John Deere 4200, Kubota ZD 326 & ZD 21
I thought I would show off some pictures of the pulverizer i had recently finished, that is if I can figure out how to post pics.
/ Pulverizer
here is a section of land before the pulverizer went over it. this is just a potato field across from my house that I was testing it in.
/ Pulverizer
A picture of the ripping shanks in the ground.
/ Pulverizer
and a after shot. This was just one pass and it was pretty compacted from the 7920 that was in the field earlier.
/ Pulverizer
and the machine that pulls it. NH 1925 34hp, needs 4x4 and at least 2nd range sometimes 1st to pull it through the first pass.
/ Pulverizer
I guess thats enough showing off for now. ( don't you just love new attachments:D ) Feel free to ask any questions or comments on how it could be improved. thanks
/ Pulverizer #7
That looks great! Nice fab work also:D
Just a note though, you can add more than one attachment at a time to a single post...
/ Pulverizer #8
How did you get the spikes in the roller and what does that baby weigh? Nice job on the fabrication.
/ Pulverizer #10
Looks great! I wanted to make a pulverizer too but never could find a I beam. Very good!
/ Pulverizer
thanks for the complements guys. the roller was actually 2 sections of 6" sch 80 pipe that I found in the scrap yard. Cut them to length then welded the to pecises together to make it about 5' 10". then I cut out the end plates from 3/8 plate and put the 1" solid shaft through it. But the shaft is not full lenght because that would cause it to bow in the middle so instead I made two parts for that look like this l----l- and they slide into each end. As far as the spikes on the roller they are 1/2 " round by 1 1/2" long. They are spaced 3" apart and are 8 around making for 192 very tedious welds.
/ Pulverizer #13
That's some nice welding - and a lot of it too!
Did you fill the pipe to make it heavier or is it heavy enough as is?
jb
/ Pulverizer
I thought about filling the pipe with something but it weights around 100-120 now so the should be enough, although I would like to get some heavier springs to give it more down preasure.
/ Pulverizer #15
Looks like a good building job to me. I've seen pulverizors on skid steers that had two rollers. But I guess you don't want to make all those extra welds for a second roller!
I've been to PEI and fondly remember "fries with the works". The works of course being the peas and such. Beautiful place.
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
KUBOTA SVL97-2 (A65643)
KUBOTA SVL97-2...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2000 Sterling L9511 Triaxle Dump Truck, VIN # 2FZNNWYB8YAB42893 (A65563)
2000 Sterling...
NEW Landhonor Diesel Fuel Transfer Pump (A62679)
NEW Landhonor...
