Rear Finish Mower Pull type
/ Pull type #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
Does anyone know of a good rear finish mower that is pull type like a 60 or 72"? I have a New Holland TC29D with a 72" mid mount right now and am doing more things with it which means taking the deck on and off more. And quite frankly it is getting to be a pain to take on and off. You are supposed to be able to pull it out from the side but with the super steer bar underneath the tractor you can't. I have to raise the front end of the tractor to get on and off and even then as I get older that mower deck is extremely heavy to move. I have lots of trees so the 3 point hitch one is not an option.
Many years ago I saw one and was posted here but can not find it any more and am hoping someone here has seen something that would work. I thought of buying a 3 point one and converting but not sure how that will work on my side hills with all 4 tires being able to rotate. I guess I could weld the ones on the back.
/ Pull type #2
How about converting you mid-mount to front mount. Run it up front like a snow blower.
/ Pull type #3
I don't see any advantage of a pull type finishing mower over a 3PH type since both would be behind the tractor...right?
Or, are you looking for an offset mower of some sort to get under the trees?
Am I misunderstanding your post?
/ Pull type #4
I never completely understood peoples opposition to 3 point mowers either.
I have never had one, but I used to "mow" with a bush hog a LOT and I could mow almost as close to trees as I can with my eXmark, and I am sure it is as close as I could get with a tractor belly mower
/ Pull type #5
What about a 3pt finish mower? They seem to be 18-26 inches shorter than similar sized rotary mowers and should give you a cut very similar to your mmm
/ Pull type
The problem with a 3 point is the trees. When you turn around the trees trying to get close the mower in the back goes out and the mower can't get close enough. I have tried the 3 point already and will not waste my money on one so it can sit in the bushes like my neighbors does. Heck I wouldn't even have to buy one as my neighbor would probably give me his.
/ Pull type #7
But, wouldn't a pull type do the same thing?
I suppose a pull type (if even available) would allow for some turning (limited by the rear tire clearance and PTO driveshaft) would be a bit more flexible.
There are two behind mowers...I've seen them advertised for ATVs and UTVs. These are self powered, something like this:
Swisher 60" 14.5 HP Finish Cut Tow-Behind Trailmower T14560A#
Think that's what you need?
(BTW, if that link doesn't work, search for this:
/ Pull type
A pull type hooked to the drawbar would stay to the inside of the tractor. The ones you listed I have seen before but was hoping to get on to run off the PTO.
/ Pull type #9
I would think the potential angles with a pto and pull behind would/could get to intense for the universal joints to handle
/ Pull type #10
I'd also be worried about the mower hitting a rear tire when making a turn...that could result in a bad day!
But, there are pull type rotary cutters..and a number of people operate them. Maybe someone will chime in and tell us what prevents PTO damage and the tire interference.
/ Pull type #11
Try your local TSC or similar store. Even if they don't carry it in stock, They should be able to order it in for you. My local TSC does not carry the land plane, leveller, etc. But in the catalog of equip. manufacturers the carry it was listed and were able to put it on order for me. they should be able to order in a pull rotary mower for you. or a finish mower if that is what you need.
Good luck
Tom
/ Pull type
Tom
Thank you for that. I will call them tomorrow. I have checked them out but only their catalog.
/ Pull type #13
Don't know if I have ever seen a PTO driven pull behind mower, but you can solve the tire interference by using a drawbar to pull from.[ame=http://www.amazon.com/Special-Products-04010100-3-Point-Drawbar/dp/B004RQ1PRK]Amazon.com: Special Speeco Products 04010100 One Piece 3-Point Hitch Cross Drawbar: Automotive[/ame]
/ Pull type #14
Have tried using a pull-behind brush hog run off the PTO and it is a PITA. Turn too sharp and the U joints let you know.
/ Pull type #15
On my tractor the mower is hydraulic and mounted on the front. 96" of pure brilliance. Why not go in a different direction and mount a hydraulic mower upfront?
/ Pull type #16
two CV joints ( one at tractor one at tongue pivot) on the MoCo lets you turn sharper than single U-joint. I think single U is about 15 degrees, CV close to 30*
/ Pull type
I am not sure the hydraulics on my tractor could handle it.
/ Pull type #18
Another way to avoid tires hitting the mower on turns is a swinging hitch but I don't know if they put them on newer machines.
/ Pull type #19
The big advantage a 3 pt mower has over my riding mower is that it still cuts when I am going backwards. And because it was so low to the ground, I could back it in to any corner or under any tree, without having to worry about it getting hurt. I think that motor sitting right on top of a pull behind would have got in the way.
PORTA POTTY (A68842)
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2018 PETERBILT (A68134)
2018 PETERBILT...
2018 BRADLEY MACHINE MINI VAC TRAILER (A67714)
2018 BRADLEY...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A66736)
2020 Mack Anthem...
2023 Chevrolet Express 2500 Cargo Van (A61573)
2023 Chevrolet...
