Pto
Atiger
Allis-Chalmers
I have an Allis-Chalmers 1952 And was wondering on the belt PTO Can it run all the time with even with the clutch push in
It's been along time since I ran a belt on a WD Allis, and I can't recall all the steps to run it.
I do recall a lever (dog) down by the clutch pedal and when that was flipped into place the clutch was held in and I believe the belt pully stopped.
That was after the belt pully was put into the run position using the jam nut and bolt that held it in the operate or non-operating position.
When it was physically disengage by sliding it out (I believe) about an inch it wouldn't be powered.
So to answer your question I recall it stopping with the foot clutch.
/ Pto
Ok it runs my front bucket it痴 an hydraulic pump and it痴 hard to run all the lifts lol
Does your Allis have the hand clutch?
That was what gave us a kind of independent pto and hydraulic lift on the WD.
belt pulley stops with foot clutch in
Hard to give an answer, when you don't even tell the model of AC you have...
SR
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
3 POINT BEAR CAT 71854 WOOD CHIPPER (A65643)
3 POINT BEAR CAT...
New/Unused CFG Industrial MX12RX Mini Excavator (A65579)
New/Unused CFG...
