PTO Speed
/ PTO Speed #1
KiotiWarhawk
Camas WA
Looking
I recently bought (translate - I'm a newbie) a CK25HST (great machine by the way) and have yet to use my first PTO implement. My Tach has a PTO speed indicator (orange / red triangle). My question is do I ALWAYS want to run the tractor at this speed when using a PTO attachment? I obviously don't want to run faster but would I want to run slower? I have a 12" auger that I am going to use for some "hole" work and if the ground lets me, do I want to run slower?
thanks
Craig Orput
Camas WA
/ PTO Speed #2
Welcome to the pack KiotiWarhawk!
I would NOT run the PHD at full bore until you're sure you're comfortable with how it works. Run it for what the task at hand calls for.
I run my (9" x 42") at about 1,800-2,100 RPM. Never really had to run it full bore and I have clay, rocky ground. Hope this helps. Gerard
/ PTO Speed #3
As Gerard said, not for the PHD. It is not necessary to run at full PTO speed for other applications such as light cutting with a mower. Don't however, go too low as it may stress the engine. For non-PTO operations, you can run it pretty much where you want as long as you're not lugging down the engine. John
/ PTO Speed #4
I run my post hole digger at idle speed (easier to lift or stop if I snag a rock) to prevent breaking a shear bolts or getting the auger stuck in the ground.
I rev the engine once in a while to throw the dirt from the hole.
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2007 International 8600 Parts Truck (A63689)
2007 International...
2007 CM TRAILER 18' T/A ENCLOSED TRAILER (A65643)
2007 CM TRAILER...
Kubota SVL 97-2 Skid Steer (A65579)
Kubota SVL 97-2...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
