PTO shaft sizes
/ PTO shaft sizes #1
HODAK
NE Pennsylvania
CK30HST
Can someone confirm that the PTO shafts are the same size for CAT I and CAT II? I know the lifting pins are different sizes, but I'm not sure if the shafts are both the standard 1 3/8". Thanks!
/ PTO shaft sizes #2
Modern 540 RPM PTO shafts are the same size. The 1000 RPM PTO shafts on larger tractors are different. Hope this helps.
Lewis
/ PTO shaft sizes #4
The "size" of the splined shafts are standard (nowdays) but those shafts are all available in different HP ratings. A shaft for using on a 100 HP tractor and bush hog combo would be MUCH heavier than what would be common to a 4' finish mower for a 25 HP tractor.
2014 CATERPILLAR 573C FELLER BUNCHER (A65053)
2014 CATERPILLAR...
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
213087 (A64276)
213087 (A64276)
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2010 Kenworth T3 Class 7 Flatbed, 4x2, w Tuck-Under Liftgate (A63689)
2010 Kenworth T3...
1997 Titan Gooseneck Trailer (A66285)
1997 Titan...
