jezorek said:Can anyone tell me what the minimum safe engagement is for a telescoping PTO shaft?
Ideally you want to cut your shafts so that there's at least an inch of collapsable length left at the shortest point of travel - AND - no less than 6" of overlap left at the longest point of travel.jezorek said:Can anyone tell me what the minimum safe engagement is for a telescoping PTO shaft?
Whereas an ORC will secondarily serve to compensate for a short PTO shaft, it's an unnecessary expense - and one extra moving part to break. More appropriate to the task is the simple PTO adapter. Same catalog, different part number(s):teg said:For shafts that are too short, I bought an overrun (over riding) clutch...
greg_g said:Whereas an ORC will secondarily serve to compensate for a short PTO shaft, it's an unnecessary expense - and one extra moving part to break. More appropriate to the task is the simple PTO adapter. Same catalog, different part number(s):
Agri Supply - Where we have Something for Everyone for your Farm Shop & Home
//greg//
Yes. But in some cases that's just downright expensive. Example: I added Cat 2 PEC to my 45 horse. Doing so effectively extended the lower lift arms by nearly 4 inches. That in effect made ALL my PTO shafts too short by 4 inches. Instead of buying half a dozen new shafts, I got a 4 inch PTO adapter.Highbeam said:Rather than use the adapter wouldn't it be wise to just order a new PTO shaft?
bjcsc said:flusher: you are far braver than I. No way would I have all that spinning behind me (ORC and SlipClutch) without a guard. Don't you worry about what could happen if any of it failed during use? It gives me the willies just thinking about it...
flusher said:Here is the hookup to attach my rototiller to the Kubota B7510HST
The overlap on the pto shaft sections is not more than 5 inches. It works fine.
Had to cut a shaft that I bought at TSC to get it to fit between the tractor and the slip clutch (the tiller doesn't have shear bolts, hence the slip clutch).
Don't need an overruning clutch since this is an HST tractor.
Needed to add that pto shaft extender onto the tiller to keep the slip clutch from rubbing on the tiller sheet metal.
This made the drive train too long for the 26" lower arms that are standard on the 7510. Had to use the 35" arms from my 1964 MF-135 diesel to get enough room to handle all that drive train stuff.
Soundguy said:I'm wondering if you could have reversed the hookup.. IE.. slip clutch to tractor pto stub, and then telescoping shaft to the tiller.. thus eliminating the extender and buying you a few more inches of overlap.
while the vast amjority of slip clutch setups i see are at he implement side.. I have seen some oem setups with a torque limiter on the pto stub side..
soundguy
flusher said:It's a rototiller, so the pto shaft rpm is pretty low (200-250 max).
And I have my backside covered with that expanded metal safety screen attached to the ROPS
I'm more concerned about stuff flying in my direction from my brush hog. That's why the screen is there.
Im not familiar with a need for PTO braking. Why are they employed on some systems?Soundguy said:Good point about more parts to wear, if the ORC properties are not needed.
I can think of one situation where the ORC may not be needed.. but might be usefull.. like in a situation with a large flywheel load on the pto, where you might want to save your pto brake.. IE.. a large mower or a chipper.. with an ORC.. it could spin down instead of havinghe pto brake grind it down to a stop.. etc..
soundguy
