PTO seal which ways which!!
/ PTO seal which ways which!! #1
Masseymad18
Masses Ferguson. Ford
Hi all I'm replacing the PTO seal on my MF. Which side should go against the oil and which faces out.
Always thought the spring side in faxing oil but it's really hard to fit that way. Fits nicely the other way?
Thanks
/ PTO seal which ways which!! #2
typically seals go with metal facing out . not sure on your tractor tho
/ PTO seal which ways which!! #3
Thanks
The side you show in the first photo faces out. The rubber lip should angle towards the oil side.
Thanks guys for the reply. That's the way that's very tight alright. Hopefully I don't damage it putting it in!
/ PTO seal which ways which!! #7
Thanks
That's why I'm attached to my cell phone - take pictures on disassembly.
/ PTO seal which ways which!! #8
Yes. Imagine some pressure building up against the seal from the oil. With the lip facing in towards the oil, the seal will be pressed tighter against the shaft due to the pressure. If the lip were facing the other way, the pressure would tend to lift the rubber away from the shaft, allowing the oil out.
Thank you all for your replies. I thought thats how it goes on and as stated by someone above I always take pics before and during disasambly. It's so helpful
However!!
This is the second pto seal I've put on as the new one before this leaked just after it was installed and I see the problem on this one.
New pto shaft btw
I put the pto seal in the pto collar/retainer. Pushed the collar onto the shaft. (Really tight and and each time the outer lip of the seal is partly sticking.
So then I tried a different approach of putting the shaft into the housing and equally pressing the collar in on its bolts but it still happens
Not in the same area each time may I add it's hit or miss.
I took the seal pack to the shop and he gave me a new one but it still is happening?
What's up I wonder.
I've pointed to the area I'm talking about in one pic.
Thanks
/ PTO seal which ways which!! #10
However!!
New pto shaft btw
What's up I wonder.
Thanks
Try putting the seal on the shaft the easy way and let it sit overnight. Then grease everything good and turn it around to the correct orientation the next day. It should go easier. Use some popsicle sticks to help the lip onto the seal surface on the shaft.
/ PTO seal which ways which!! #11
However!!
New pto shaft btw
What's up I wonder.
Thanks
On these photos it do not looks right. Seal or shaft not right.
/ PTO seal which ways which!! #12
Are you lubricating the shaft before you put the seal on? I prefer a heavy oil to grease for that, but any lube is better than none.
For a seal I had to slide over a long shaft on my Coot, I wrapped light card stock around the end of the shaft, slid the seal on to that, then slid the seal and card almost up to the seal's final position, then slid the seal of the card stock and onto the shaft. This protected the seal from getting damaged while sliding it along the shaft. A very thin sheet of plastic might work as well (cut from some junk that might otherwise go in the recycle bin). THere was some trick I did to get a grip on the card to slide it, but it's been a long time, and I can't remember what I did right now.
Snap John I looked at it and came at it so many was yesterday. Then said to myself I need to.create some sort of thin slide to slip over the shaft where the seal goes to stop the lip from catching on the shaft and folder over creating the problem I was having.
So i got some really fine cardboard and slid it down and onto the shaft. Put all back into the tractor, filled with oil and no leak!
I had done a seal years ago on the old.shaft so I was very frustrated as to what was going on.
It's a good tight seal but you can't renew it like the MF manual says.
Thanks all for your reply
/ PTO seal which ways which!! #14
Yep, in our maintenance department for the corporation where I was employed for 38 years, we used either plastic or brass shim stock to wrap around the shafts to slide the seals over in the gear boxes we rebuilt . It kept the splines and key key ways in the shafts from cutting the new seals. Along with lubricating the new seal with grease before sliding it on. ;)
/ PTO seal which ways which!! #15
Electrical tape is also an option for some seal installs.
Komatsu D65EX Dozer (A66285)
Komatsu D65EX...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
KENWORTH CAB AND HOOD (A65643)
KENWORTH CAB AND...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
John Deere 7000 6R Planter (A66285)
John Deere 7000 6R...
