PTO Relocation
/ PTO Relocation #21
Nope, your stuck with OEM stuff for the front (barring options listed above) but $1900 for a front snowblower is NOT a bad price...
No, the subframe/mount is $1900, the total is $5800, blower, mount and all accessories. I prefer using the mid-pto for front mount applications, but for that price, I think I will stick with the rear blower for now.
/ PTO Relocation #22
WOW:eek:
And they say John Deere is expensive...:)
/ PTO Relocation #24
Woods used to make a pto angle linkage set that sent the rear pto forward for a mid mount mower.. could modify that for full front..
soundguy
/ PTO Relocation #25
What about a hydraulically driven Skidsteer blower and tapping into your tractor hydraulics?
I have no idea if your 3510 has enough flow rate but thought I would toss that idea out there. Maybe a PTO pump and some long hoses?
/ PTO Relocation #26
This is just one other option you might consider, but that is if you ;have the hydraulic GPM's. A hydraulic motor up front to drive the snow blower.
/ PTO Relocation #27
Bervac also made a similar underslung reverser. Was 'chain & sprocked' drive affair and the setup was kinda like hanging a ladder under the tractor with a supported driveshaft.
Both front and rear used standard PTO type shafts.
Still have the one that came with my blower that I reverted to std rear as I prefered to retain my loader capabilities and not do the 'seasonal switchover' twice a year.
The bervac unit was 'adaptable' to many standard rear blowers with advantage being the std 550 RPM.
/ PTO Relocation #28
That is the brand I have for sale a BER-VAC 1125 front mount frame for use on 12 to 30 hp tractors(from the manual).Ken
2018 Ford F-150 Ext. Cab Pickup Truck (A66736)
2018 Ford F-150...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
2026 57in Rotary Brush Cutter Skid Steer Attachment (A66734)
2026 57in Rotary...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
WEATHER GUARD TOOLBOX (A68842)
WEATHER GUARD...
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
