PTO Pump Pressure Check
/ PTO Pump Pressure Check #1
Wayne_Freeman
Beaufort, SC
Kubota L3400
I purchased a used Kubota 4690 Backhoe/w PTO pump. The unit is working but seems to be weak. I don't have a manual but would like to put a gauge on the hydraulics and check the operating pressure. Can someone give me a heads up on how to do that?
/ PTO Pump Pressure Check #2
Find a gage. 3000 psi or more. Target value is between 1500 and 2500, depending on mfg spec.
Determine the size connection from a hose to an easy to get to cylinder. Probably JIC #8 at a guess. Get an adaptor to mate the gage to the hose. Move the control and hold to measure the pressure. The relief valve will only let it go so far. That's it in a nut shell. Surplus center will have everything you need.
jb
2025 Ranger 1000 XP Northstar Premium (A62679)
2025 Ranger 1000...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
2019 Lynco Mini Mover Aircraft Tug Cart (A61567)
2019 Lynco Mini...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
