PTO Hydraulic
/ PTO Hydraulic #1
LarryP
I have a Satoh 630D and my PTO arms is slowly lowering , usally takings several minutes or longer to lower. Is there a filter that I need to clean on the hydraulic system or is there something else wrong with it?
HELP!!!!!
/ PTO Hydraulic #2
Not sure what "PTO arms" you are referring to, but assume you are talking about the 3-point lift arms supported by the rock shaft. There is likely a valve (knob or lever control) that can be opened to allow the lift arms to drop faster. Check the manual, or look around under the seat for such a knob. PS: PTO stands for Power Take Off and is the drive shaft for powering equipment such as a rotary cutter. I hope this helps.
/ PTO Hydraulic #3
I am not familiar with your model, but on my MT180D there is a knob under the seat that effects the speed the 3PH raises and lowers. There is also a filter for my transmission/hydraulic fluid. It really helped the speed of my FEL when I cleaned the filter. I did not notice a change in the 3PH, but it is worth a try since you need to clean that filter regularly anyway.
I hope that is helpful.
Robert
2001 Ford F-650 18ft Rollback Truck (A61573)
2001 Ford F-650...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A65053)
2018 VOLVO SD75B...
2025 72in Hydraulic Grapple Rake Skid Steer Attachment (A61572)
2025 72in...
2012 International Prostar (A63118)
2012 International...
2021 BOBCAT T62 R-SERIES SKID STEER (A64279)
2021 BOBCAT T62...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
