PTO Hydraulic
/ PTO Hydraulic #1
LarryP
I have a Satoh 630D and my PTO arms is slowly lowering , usally takings several minutes or longer to lower. Is there a filter that I need to clean on the hydraulic system or is there something else wrong with it?
HELP!!!!!
/ PTO Hydraulic #2
Not sure what "PTO arms" you are referring to, but assume you are talking about the 3-point lift arms supported by the rock shaft. There is likely a valve (knob or lever control) that can be opened to allow the lift arms to drop faster. Check the manual, or look around under the seat for such a knob. PS: PTO stands for Power Take Off and is the drive shaft for powering equipment such as a rotary cutter. I hope this helps.
/ PTO Hydraulic #3
I am not familiar with your model, but on my MT180D there is a knob under the seat that effects the speed the 3PH raises and lowers. There is also a filter for my transmission/hydraulic fluid. It really helped the speed of my FEL when I cleaned the filter. I did not notice a change in the 3PH, but it is worth a try since you need to clean that filter regularly anyway.
I hope that is helpful.
Robert
213104 (A64276)
213104 (A64276)
2020 Deere 544L (A60462)
2020 Deere 544L...
2018 Dodge Charger (A61574)
2018 Dodge Charger...
2017 FREIGHTLINER CASCADIA  6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2017 FREIGHTLINER...
2011 Ford F-250 Pickup Truck (A61573)
2011 Ford F-250...
JOHN DEERE 8' OFFSET DISC HARROW (A64276)
JOHN DEERE 8'...
