PTO Horsepower
/ PTO Horsepower #21
I don't know if this holds true for the newer Montanas, but the guy we bought our 4340C from said he sold one of the older Romanian made (re-badged Long) tractors that was rated 65HP to a guy that had a rather cool experience with it. The guy's neighbor had a big implement (can't remember if it was a big hay baler or a large bat-wing cutter) that he was struggling to pull with an 80hp John Deer. The guy takes his 65hp Montana over, hooks up to the implement and takes off with no problems whatsoever. The neighbor says that shouldn't be possible so he hops on the Montana and give it a try and sure enough it pulls the implement just fine. With both guys scratching their heads at this point unsure how a 65hp Montana could out-pull an 80hp John Deer they loaded up both tractors and too them to a dyno. Turns out the 80hp John Deer was only putting out around 73hp to the draw bar, but the 65hp Montana was putting out 85hp!!!
After a little investigating and testing a second Romanina made Montana and getting similar results they decided that either there was a mistake in translation that caused the engine to only be rated 65hp or the enings are seriously underrated due to poor fuel quality in the county of manufacture.
I know that most of the Mitsubishi S4 series engines are slightly under-rated as well. A 45hp Mitsubishi S4E or S4Q engine may actually give you 50hp or over. (Our dozer is an S4E and our 2008 4340C is an S4Q and the engines are almost identical)
That is probably a KW rating on the Montana.... The KW to HP conversion comes out almost exact. 1000W/746 = 1.34HP per kw =~ 85HP for 65kw.
larry
/ PTO Horsepower
In answer to a previous question, my 3040 has the Mitshubishi engine but I would have to check the series. I will measure my wheel width. It has Titan tires industrial tires.
/ PTO Horsepower #23
larry
Interesting. If that is the case then somebody missed a really important fact in translation of the brochures and the owners are going to be exceptionally pleased with what their new tractor is capable of.
/ PTO Horsepower #24
woodsman i just finished an install on a new westerbeke genset on a boat in our shop. this also has a s4l mitsu(had to look at tag) states 26 ponies. now its easy to play hp numbers in diesels. turn up or down the rpm's, give it more or less fuel and air. it would be easy for montana/ls to coax a few more ponies out of a motor.
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
Air Hose Reel (A65640)
2017 Ford Fusion Sedan (A64557)
2017 Ford Fusion...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2020 BOBCAT MT55 STAND ON SKID STEER (A63276)
2020 BOBCAT MT55...
