Generator PTO Generator
/ PTO Generator #1
jaspmoody
Mississippi
Yanmar 2010
I have a Yanmar 2010, I know, it's GRAY market, but I love it. Anyway, I am looking for a used PTO generator that will work with my 2010. Any suggestions where to find a used generator? Jim Moody JasPMoody@centurytel.net
/ PTO Generator #2
You can generally find them at farm auctions and implement dealers. What size are you looking for? Generally you can figure and 1kw per 2hp for your tractor.
/ PTO Generator #3
Take a look here or search "pto generator" on ebay:
MikePA: Removed incorrect link.
/ PTO Generator #4
OK let's try that again! Either search "pto generator" on ebay or click on this for the same result(I hope)!
Shortened Long Link
MikePA: Please review your message before posting it. It's simple not to create a long link that widens the entire thread. Just insert a descriptive word or two between the {url=http://whatever}<font color="red">Enter words here</font>{/url} instead of the entire URL. Replace parentheses {} with square brackets in previous example. Alternatively, if you use the Instant Markup language URL link, the first prompt is for the URL. The second prompt is for a description. Do not simply paste in the URL again. Type a short description of the link.
/ PTO Generator #5
I bought a used PTO driven ALTERNATOR at a farm auction several years ago. Dairy farms keep them on hand in case of power failures, in order to keep the milk tank (cooler) running. They sell high, but are worth having when the lights go out.
/ PTO Generator #6
So, what's the difference between a PTO generator and a PTO alternator?
/ PTO Generator #7
Not much in the practical sense.
About the same difference as a generator vs. alternator on a tractor.
Alternator is less load with less demand on it.
/ PTO Generator #8
Alternators spin the magnetic field generating an alternating current that doesn't have to go through brushes, makes them less maintainence intensive. The objection I have with pto alternators is that tractor governors are less sensiive to load changes. Electronic equipment and motors can be damaged by slow or fast frequency. The governors on alternators with their own motors are much better at maintiaing 60 cycles.
Generators, on the other hand, make direct current which, without a commutator, to convert it, can be converted to alternating current using electronics to maintain the proper frequency. Everything is a trade off. /forums/images/graemlins/confused.gif
/ PTO Generator #9
Uhhhh /forums/images/graemlins/tongue.gif
There are brushless generator designs.
On a dc gen... the commie makes the current dc , by design.
Pto gens are low load when there is low demand.. just like an alternator...
The governor on my old 8n was responsive enough to keep 60 cycles on my pto gen and 120vac just power tools and lamps... Barely any noticeable drop in voltage at the meter.. and no freq drop when 10+ amp motors would kick on and off.
On the dig diesel tractor there was -0- difference from nearly full load.. to no load... just so much engine and flywheel powering it..
Soundguy
/ PTO Generator
What size, something in the 7KW to 13KW area. Nothing too large. Simply want to be able to run well, some lights, and ventilation system. I live in the Memphis area and we are subject to ice storms and tornados. Several years back, an ice storm cause power outages for several weeks. I have the motor on my Yanmar 2010 tractor all I need is the PTO generator.
/ PTO Generator #11
I too am in the market for a PTO genset in the 10-15kW range. There is a used 13kW Winco at a local dealer but it's pretty old and they don't know how if it works for $600. I may just go with a new one.
Here are some on-line links I've compiled in my research that may help you:
GenPro
VoltMaster
Winco
NoOutage
NorthStar
PowerConnection
TigerPower
/ PTO Generator #12
Jim,
First, a little late but, welcome to TBN.
I would be very interested to know what, if anything you've found for a genny for your 2010. Also, what your PTO HP rating is and how it matches up with what you have looked at, or purchased (i.e. PTO HP 2x genny kW, 2.5x, 3x...?)
As I don't want to hijack your thread, I will post my own as there are questions I have that I have not found in the threads I have searched on.
Good luck, whatever you find, or have found.
Tom
/ PTO Generator #13
Don't know much about PTO generators,but,i do have a diesel motor with a 13,000k VoltMaster generator,made in the USA. I've had this set up for 5 years and i'm completely satisfide.
Mike
/ PTO Generator #15
Check Shimon's links, above. NorthStar(tm) are NorthernTool's PTO Generators. I have no idea if this is an O.E.M. of VoltMaster or, an entirely different manufacturer.
2020 MACK DUMPTRUCK (A67714)
2020 MACK...
2015 John Deere CX15 (A64126)
2015 John Deere...
2015 Ford Transit Connect Cargo Van (A64556)
2015 Ford Transit...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
2025 Wolverine MSG-11-44W 44in Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A66734)
2025 Wolverine...
RIDGID AIR COMPRESSOR (A68842)
RIDGID AIR...
