PTO generator sizing
/ PTO generator sizing #41
Neighbor in the house behind us has the automatic natural gas whole-house generator. It is a really nice setup. When it runs/exercises pretty quiet for amount of power it's producing. Hers is a medium sized one about 14K and runs everything.
I like hers but wonder in an extended outage how long will the natural gas utility be up? In the 12 yrs we've lived there power hasn't been off more than maybe 16 hrs so I haven't been able to see how it works for a longer period. I'm messing around with gas cans & extension cords & she just goes on about her day :)
I like your propane idea too since that wouldn't be depending on a second utility. Bulky container & high cost to operate, but would run everything for probably 12 days straight or so with a 500 (400) gal propane tank and minimal fuss.
Here she is, paid 1500 for it. Surprisingly it is very quiet!
/ PTO generator sizing #43
If I had it to do over again, I would consider a propane powered whole house automatic standby generator. If you wire the transfer switch yourself, the cost is maybe twice what you would pay for a big PTO generator. I'm not getting any younger and the automatic feature would make it worth the $$ IMO.
If you heat with propane, that's the best solution in my view. We have a 1500 gal. propane tank (because it can be difficult to get up our steep driveway in winter) and a tri-fuel generator running on propane. It will run "forever" if needed, no need to get the tractor out or rotate fuel. Our outages are typically in winter when the tank has recently been filed. Just start it and it runs.
/ PTO generator sizing #44
Jcoon, unit states 25kw. It takes 2 hp to generate 1000 watts, so if you where to generate 25 kw you would need 50 hp. Most times when we use generators, we do not run them to their max output, just enough to run whatever is needed. So you could run this unit with your set-up, just not full 25kw. Remember, your pto horsepower is most always less than your tractor horsepower.Bob
Absolutely that’s the plan! I will never need 25,000 Watts, if. I had everything on in my house I may tax out at 15,000 Watts, I can always turn my tractor up anyways, they are the same engine from the 35 hp up to the 55 hp. Manual calls for 45 hp FYI.
I can’t even buy the northern tool generator assembly alone for less than 1800 shipped to my house, this came with everything for 1,500 and it’s a 1800 RPM gen head. Good deal!
/ PTO generator sizing #46
If you power a large generator with less horsepower than recommended, you must monitor the line voltage and exercise good power management. If the generator load exceeds what the tractor can maintain, the RPM will slow causing the line voltage to drop. This could cause major damage to some appliances. With thermostats, automatic timers, more than one person turning appliances on and off, etc., it isn't always obvious what the electrical load is at any given time.
If your rated generator capacity matches your tractor PTO output, the generator circuit breaker will trip before any damaging line voltage drop occurs.
My entire load is about 15,000 Watts, and that’s everything I have on at once. And the water heater doesn’t run in the winter so take that out of the 15,000. Tractor can make about 15,000 Watts.
/ PTO generator sizing #49
I've never over loaded my 12.5 pto hp tractor with my 15kw pto generator, it just hums along nicely powering my home...
IF I was worried about THAT, I'd put a breaker the size my tractors pto will put out, between the gen and the house. Very easy to do...
That way, if I exceed the tractors out put, the breaker will let go.
SR
/ PTO generator sizing #50
Only thing is, it may be (and often is) more than just "turning it up"...
Many times it's turning it up WITH bigger injectors and some other things...
I see this all the time...
SR
I understand that, but I believe the pump is just derated. I think it’s all the same injectors and turbo.
/ PTO generator sizing #52
Almost all generators have AVR. Automatic Voltage Regulator. Dropping in RPM should not effect voltage. Freq yes, but that doesn't much matter. That's why I monitor Freq. Not because it matters, but it tells me more about my loading then voltage.
Yes this generator has a voltage regulator inside in, with all kinds of controls on it, way past my pay grade.
/ PTO generator sizing #54
Howdy,
You have made a good deal.
Because of the size, you get a lot of benefits which you might not be aware of. The genhead is a 4-pole head. That means the assembly spins at 1800rpm (+-200) It is known as commercial quality. The rotating mass will smooth out any power load applied, such as a large motor start, and then simple running load. Just because you have more generator than tractor does not mean a bad thing. You would be surprised later down the road that after your hooked up and running, how little power you really need. Every now and then you might see a spike with something turning on, and then a moment later, the load is small.
It just takes some good common sense when running under generator power.
Make sure your generator connection is up to the task to feed your panel, and dis-connect from the utility.
A thread with some info for your panel connection ideas. Generator Transfer switch connection choices
It’s a Anderson style plug that feeds into a 60 watt breaker.
/ PTO generator sizing #56
Small changes in frequency are not an issue, but running something designed to run at 60 hz at a frequency of 50 Hz instead can damage some equipment, motors will run 20% slower (and possibly overheat)
/ PTO generator sizing #57
I'm guessing 50 HZ for a 60 HZ motor might be stretching it. And I don't know much about motors. I know there are better and poorer designs and higher and lower qualities. I would have no issue at all with 55 HZ. Or 65 HZ. I would however want to know why I am not holding frequency.
Usually with my small sets, the governor of the motor is simply not able to keep the motor at speed. Just like blowing snow. Heavy conditions, you lose RPM.
/ PTO generator sizing #58
Howdy,
The best thing you want is a nice clean 240 volts, 60Hz.
Equipment likes these parameters.
You need to review what your wiring gauge is. The full power outlet from the Dayton PTO generator has a dedicated circuit breaker on it. It looks to be a 125 amp breaker. For full output connector #2 AWG welding cable is recommended, and you have the Anderson power pole connectors.
Yup that’s what I’m setup with.
/ PTO generator sizing #60
Since we're on this subject, just how big of a generator would one use for an average 2400 sq ft home that is all electric?
I'm sure more information is needed but, I'm not sure what information that would be. Will check with my other half when she gets home and see what our average electric usage for winter is.
Rams
Back when I was a kid, we installed lots of electric heat. We figured 10 Watts per SF. That is 24KW for your heat if it all runs at the same time.
2005 (INOPERABLE) FREIGHTLINER COLUMBIA 120 (A67714)
2005 (INOPERABLE)...
BOBCAT 435AG (A68134)
ALLMAND  MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
2011 Chevrolet Impala Sedan (A66738)
2011 Chevrolet...
PALLET OF 2CYL GAS ENGINE/RADIATORS AN PARTS (A67714)
PALLET OF 2CYL GAS...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
