Do's and Don'ts and recommendation for buying a PTO driven electricity generator?
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #21
Yes. Yes they are.
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #22
Yes, which is why everyone has to evaluate their own situation. Households with one or two adults with no pressing medical issues might be able and willing to go without power for a few hours while a tractor is used for other tasks . Others may not, or may not want to. No two homes or families have the same needs or desires.
I'm going to have to adjust how I do things and make sure my LP tank is always above 50%. In the past, I've let it get below 20% fairly often. I won't be able to do that and will have to make sure to order far enough in advance for them to deliver if I know a storm is coming.
I'll be keeping the gasoline units as back ups.
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #23
Having done with quirks of California Utility companies failure and wild fire and earthquake and more recent the "mono winds", the power grid here is not reliable at all......... A generator is almost a must in mountain country where we have been with out power for 3 to 5 days, Ironical we get buy with a old used 6500Watt Generic stand alone .... So it works for us, but we only run it a few hours in morning and evening mainly to keep well tank full of water and keeping refrigerator cold.... Really can't see tying up my 14,000 dollar tractor and a 3,000 dollar PTO generator when a $800 (new) standalone will do.... Of course you needs will vary, but if you power loss in a yearly thing and for long extended periods I really believe dedicated system with auto start and cut over is better solution.... The 10 seconds of with out power when utility company power drops off and the standalone with auto start comes online is not really any inconvenience...
Dale
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #24
Dale
Well let's see my newer tractor was more then $40,000 my old one was $5000 but seeing as how I already have them and would have them with or without a pto generator
I fail to see were that cost has anything to do with the generator cost.
A $3000 pto generator should be a high quality 25 Kw unit or larger which will provide a 100 Amps of clean 240 Volt power,
your $800 3600 rpm screamer likely will be providing dirty power and not that much of it and your going to have to keep gasoline around to run it.
And you can not run any heavy loads with it.
But you are welcome to use what you wish to, I would never suggest such a system but you can if you wish.
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #25
My F-150 with the 7.2kw generator comes in on the 27th. I was hoping to use it as my backup energy source with a manual transfer switch. I知 trying to figure out how difficult/costly it will be to install the exhaust system that fire stations and auto shops use so I can run it with the garage door closed. We are building a home this spring and I知 hoping to plan for it rather than trying to make it work later. Weæ±*e building with ICF, so just punching a hole in the exterior wall won稚 be too easy if I don稚 plan for it.
Talk to your plumber; there are many ways to do a pipe through a wall into an access panel. Simply plug and play after that. I just ordered my wife a new 150 with the powerboost and 7.2Kw 30 minutes ago. Sometime in May is what the dealer is telling me.
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #26
Here are several hoses;
Garage Exhaust Hoses - Free Shipping on Orders Over $99 at Summit Racing
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #27
I’m trying to figure out how difficult/costly it will be to install the exhaust system that fire stations and auto shops use so I can run it with the garage door closed. We are building a home this spring and I’m hoping to plan for it rather than trying to make it work later. We’re building with ICF, so just punching a hole in the exterior wall won’t be too easy if I don’t plan for it.
He's talking about a pipe for a hose to attach to the exhaust of the truck. That will need to be done before the concrete wall is poured. Conduit from the garage to the power panel should be part of the construction plans.
That said, this is probably the least wise plan for backup power I've seen anywhere. Leaving a motor vehicle running inside a closed or semi-closed garage to power a house ... well ....
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #28
One of the best things we did was to install a 12.5 kw Isuzu diesel generator from Central Maine Diesel in December 2012. It is a little gem. Uses about 0.25 gph for an average of about 2.5 kw for our whole 200amp panel on the generator, e.g. essentially all lights and refrigs, 2 heat pumps, 1 electric hot water tank and clothes drier. Has 60 gallons belly tank.
Would not like a PTO unit. Means you'd have to get a tractor out in the worst possible weather to connect it up and to get it a EXACTLY the right rpm, and its tank is entirely too small.
Ralph
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #29
One of the reasons for building an ICF home is the protection aspect, not only from the weather. The way the country is going, living in a home with walls that can stop a .50 cal is pretty appealing. I don’t want my backup energy source exposed. That’s why I’m trying to plan for fresh air intake and exhausting the fumes. I agree there are better solutions, but the wish list is 10 pages long and the budget can only cover 5 pages. Thanks for the input on the conduit.
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #30
Stopping a 50 cal is impressive.
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #31
May want to move to a safer place !!
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #32
LOL. Agree.
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #33
I wonder how the natural gas supply for home generators is holding up in Texas. Anybody have direct experience down there ?
That's why I stuck with a diesel tractor powered Winpower 25 kW job. Plus I can get my neighbors well, furnace and battery chargers going at any time. Once my house is warm, It will stay that way for 4 hours. So I can use the tractor for a 4H parade or whatever your 'critical tractor needs' are that everybody talks about. You can pull trees out of the road, plow snow or teach driver's ed with a truck. No tractor really needed.
BTW: I was told that a log cabin would stop a .50 cal. Ain't so. My Barrett will penetrate a 12" dried oak log at 150 yards and still have enough momentum left to dent a (full) beer can.
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #34
I'd be more concerned with holding up against a Tornado. And my neighbor is a 1/4 mile away, so that'd be a fairly long extension cord.
It'd be nice to have a diesel genset, but the cost was not too nice. I wouldn't think of running my little blue bomber as a power source, even IF I could get it up to the house during a storm.
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #35
Been using PTO generators since we got the first on on the farm back in the mid 60's.
I've had portables and larger engine drive units I'll stick with the PTO's or an 1800 rpm diesel of good size.
And for those that think they are too complicated to hook up and use, they need to get good and cold to have an incentive to learn.
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #36
Here is another vote for a 25 kw pto generator. On our home farm when it was a dairy we purchased a 25 kw Onan which ran all of the milk barn, coolers and main house. We still have the transfer switch, but the Onan wore out and also a subsequent tiger power 15 kw (over about 50 years). Right now my daughter who lives at the home place has been on the pto generator since mid day Saturday. Round the clock connected to a 35 horsepower Century/Branson tractor. It burns about 3/4 gph of diesel. Other than stopping to change engine oil and service the generator, it just keeps chugging along. It is a Winco and I have been pleased with it so far.
Here in Central VA there are thousands whose power is still out from the ice. We know where the problem is on the farm with a broken line. But this line only serves 3 connections and so is low on the priority list. I live on a different leg and only was out of power for about 3 days. And I have a small 6600 way Northstar that i use for essential circuits in my house. As others say it really depends upon your particular situation and needs. Both of these options have worked well in our case.
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #37
Ive got a 17kw propane backup with auto switch, been out of power since Saturday morning. Propane tank ran empty last night with delivery scheduled yesterday but not showing up. PTO generator is much easier to refill and stockpile fuel for. I will be getting a generator plug added to run a smaller generator in the coming weeks once the local electricians get caught up. In central VA supplied by Southside Electric Co-Op, they have gotten about 1/3 of their customer restored to power since Saturday.....
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #38
Ralph
Those Isuzu gensets are really nice, but it only cost me $1,200. for my 15kw Winco pto generator, and now I have a nice diesel generator...
I don't see any reason a guy can't put a small enclosure/shed by their house to keep their tractor and pto generator in, and run a wire to your house, not really any different than wiring for a stand alone generator, other than it's not auto start. That part doesn't bother anyone here, my wife says she's not helpless... lol
I keep fuel around for the tractor, so it's no big deal to keep some close to the tractor to fuel it once a day or so...
SR
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #39
When I built my shop I ran a 200 amp service to it from my 400 amp house service. I park the tractor and generator in my shop, hook the cable to the 100 amp welding plugs on each end, line up my breakers and let it run.
/ Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #40
My well used 7kw Generac broke down last year and I replaced it with a 15kw PTO generator from Winco. Other than testing I haven't used it yet. I agonized over the various issues with dedicating my one tractor to producing power, mostly because I use the tractor for contract snow plowing. In the end, I realized my plow run is 2-3 hours at a time, and hooking up the generator is painless.
I moved half a dozen circuits from one 200a panel to the other 200a panel, which is manually switched over with an interlock. My electrician neighbor has been great in getting it all done. This spring I want to put an interlock on the the other panel so I have full (selective) control.
In addition to the expense concerns, a big consideration for me was the hassle of storing gasoline for the Generac. Diesel is easier to handle, and stores better / longer than gas (plus I already carry 37g of diesel in a transfer tank in my truck).
18ft T/A Flatbed Trailer (A59231)
18ft T/A Flatbed...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A60430)
UNUSED SET OF...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61306)
2021 Takeuchi...
UNUSED KJ K1912 - 20' X 12' LIVESTOCK METAL SHED (A60432)
UNUSED KJ K1912 -...
