Generator PTO generator feedback
/ PTO generator feedback #172
The Honda's are nice. Well worth the extra money.
They are. I never had problems with mine but the dealer that sales them at my lake has a lot come back with bent piston rods??? Not too sure why??? There are now many Chinese clones on the market and they are just about as nice and can be had for $400 for the 2000 Watt version. Yamaha also makes a 2000 watt inverter type that is now outselling the Honda around here after the bent piston rod issue a few years back. I can not tell the difference in sound, fuel consumption, or weight from the Honda. Same with the Chinese clones but they may be a tad bit louder but not sure, may be me just thinking that since they are less than 1/2 the price.
http://cgi.ebay.com/2200-2000-WATT-...iewItemQQptZBI_Generators?hash=item2eaa31c33f
A big issue we see is most boats and campers have 13,500 BTU heat and air and the 2000 is just a little small to start it. Yamaha has came out with a similar genny, about the same size weight fuel consumption noise ect, that is 2400 watts and they guarantee it to run 13,500 BTU heat and air. Its They saw a need in the market and met it.
Yamaha Generators main portable generator page with models description and application guide with specs and features
Chris
/ PTO generator feedback #173
I dont need much more than 6000w for my backup needs. I only own one tractor with PTO. i've debated 12kw pto genny since buying my tractor in 1999. My solution was a Yamaha 6600w gas unit. Superb engine and great generator says my electric guru. Runs over 12 hrs between fills, burns "no" oil , easy to transport on wheels. Capable of running 2.5 or 3 ton Heat Pump for cooling, well pump and air handlers easily. No, not everthing at once , but I power different circuits depending upon weather. I back-feed my board responsibly. Usually have 50 gals gas on hand, plus what is in my vehicles. Since getting the Yamaha 9 yrs ago, I bought a RV with a 20kw Kohler Diesel genny and 300 gals onboard diesel. The Kohler puts out over 80 amps. I have been meaning to run a "buddy plug" off this unit to power the home, but it's still on the list. I can always retreat to the RV, if I dont have to keep pipes from bursting in the home. I have taken my 200 lb. Yamaha off site to help others . Just throw it in the back of any SUV, truck. Moving the tractor and PTO genny off site not as easy. I dont have oil heat, if you have 250-500 gals of oil at home that can power your tractor, I think a $1500 12kw+ PTO is a no brainer. My back up power concerns are more focused on getting by 2-3 weeks off the grid due to an ice/wind storm, than the 12 hr outages. Now if I needed abreathing machine or was raising birds etc. i would plan differently. I have noticed my neighbors with "cheap" 5-6kw gas gennies who dont maintain them like "us guys" having genny failures over the years.
/ PTO generator feedback #174
An RV with 20 KW genny and 300 gallons of fuel, must be a hotel on wheels :)
/ PTO generator feedback #175
/ PTO generator feedback #176
I'll jump in here ref the OP's original question. I have 3 generators: A 7500 watt Sears, a Boliy Pro 3600 watt Digital inverter generator and a 25KW Winco PTO generator.
The sears model I bought when I was in FL during the "hurricane spawning years". It uses quite a bit of fuel and is rather noisy, but it does a good job. Think about it, when everyone's power is out, you will be standing in line to fill all those 5 gal fuel jugs...been there done that.
The Boliy I just bought over a month ago for camping. I have put over 50 hrs on it and the thing is quiet and powerfull and only weighs 77 lbs, sips fuel....love it!
The Winco I got from a friends dad...$450. It has a 15, 50 & 100 amp breaker, and a amp meter. My 40 horse tractor puts the amps right in the sweet spot at 2k rpm @ 540. My tractor burns around a gallon an hr at this rate. I wanted the Winco to plug into the house during ice storms, and to run EVERYTHING. It does it no problem. I can also throw the Millermatic 210 in the bucket, hook up the Winco and go weld anywhere on my place.
I am not scared to run my tractor as needed to power the house, and I have a 300 gal diesel tank, so re-fueling is not a prob. I think a large pto generator is a great thing....powerfull and versatile. With the sad state of gasoline these days(ETHANOL), all of our small engines are experiencing more and more fuel/carb related problems. And, they just upped the ethanol content again, so it's just going to get worse. So, it's nice not to have another small engine to worry about. Jmho.
I will be selling the Sears genset, even though it is a good unit...I just don't need it anymore.
RD
/ PTO generator feedback #177
I have an interesting Twist to add to this discussion that I'm surprised isn't listed or mentioned in the first 16 pages...
How about an engine driven Welder ??
Miller - Engine-Driven Welders, MIG/TIG/Stick Welding Equipment
When the wife said WE need a generator.. I said I want a welder.. and it was a match made in heaven. I understand most farms have a need for a welder and backup generation For me it's a great compromise between a standalone generator and a PTO generator.. it never just sits until needed like a generator and it doesn't tie up a tractor when needed. You can get them in Gas or Diesel and for me was a good option.
They even make 1 with a 3 phase...
/ PTO generator feedback #178
Only problem is many of the entry level ones are just 110 volts designed for using power tools on the job.
I've got a Honda 170 amp dc portable like that, you have to step up to those pro quality units to get 220.
Right now is the best time I've ever seen to get a good deal on a great welder/generator. They are on Craigslist everyday.
Definitely not the cheapest option, though you are killing 2 birds with one stone, so might be just the answer for certain circumstances.
JB.
/ PTO generator feedback #179
MAKE SHURE YOU CAN RUN THE ELECTRONIC CONTROLS ON YOUR FURNACE, DISH WASHER, COMPUTER AND WHAT EVER ELSE WITH BACK UP POWER. I THINK IT IS CALLED CLEAN POWER. WHAT IS SINE WAVE? LOOK AT 1800 RPM GEN SETS
/ PTO generator feedback #180
JB.
Of the Lincoln, Miller, And Hobart welders, They all put or 220 V in generator mode, I would be shocked to find any setup for only 110... yes they are a little more $$ to start with then generator only units you would find at Home Depot but they would be multi use at a home, farm, or even small ranch, and not just collect dust in the garage. Again not saying its perfect, but for anyone that wants under 20KW and would rather not use a PTO here is an option especially if you need, want or enjoy welding. They even have some 3 phase options which I have heard some farmers use on water pumps ETC..
mylincolnelectric.com
Hobart Welders - Products - Generator/Welder
I dont' sell anything, not affiliated with anyone just passing on a idea
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Service Truck Body (A59230)
Service Truck Body...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2018 Toyota C-HR Hatchback (A59231)
2018 Toyota C-HR...
iDrive TDS-2010H...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
