PTO EXTENSION
/ PTO EXTENSION #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I recently installed Pat's easy change on a TC40DA. The installation went easily and it makes hookup much quicker, as others have said. I haven't tried to use my Woods 72" brushbull yet, but sort of expect to need PTO extension due to longer lift arms. Question is how much leeway does one typically have in PTO hookup. I don't really want to experiment with running cutter in potentially dangerous situation. Thanks in advance
/ PTO EXTENSION #2
Well in this older thread I recommended the agri-supply extender
shorter lower arms
Your woods manual (pdf) doesn't seem specify a minimum overlap, but I like to see a few inches at maximum extension.
To measure the overlap - slide the PTO apart and attach the tractor half to the tractor. Line up both shafts side by side to measure the overlap.
/ PTO EXTENSION
Thanks, I'll try that.
/ PTO EXTENSION #4
I added Pat's (Love it) and found out my tiller PTO shafts were too short then.
I think the only safe way is to take the shield off, hook it up with the PTO shaft NOT together. Then lift the implement to check if it bottoms out. Then lower the implement to check for overlap. Be sure to account for the rear tires going over a hump and the implement being in a hole, or lowered to max depth.
I still have to extend my shafts and get a new shield--the old ones were chewed up due to being too short.
My 2 cents.
ron
/ PTO EXTENSION #5
Flintlock - if your PTO drive shaft works without issue before installing PEC, just add the PTO extender and you'll be back pretty close to where you started. The extender is advertised to give you 4 inches. Pat Greenwell says his Cat 1 PEC adds 3.75", and his Cat2 adds an even 4". Not sure about Cat3, don't actually know of anybody who's bought that size yet.
//greg//
/ PTO EXTENSION #6
I tried the item number (11971) on agri supplys web site for the pto extender??? nothing found could some one help me with what I am looking for...I would like to have one of these. Thanks
/ PTO EXTENSION #7
It's not the easiest site to navigate, perhaps this will help: ASC # 11971
//greg//
/ PTO EXTENSION #8
Thanks so much greg....i thought i coud find it myself but you are so right that is a tough web site.......Thanks again though.....that is just one of the many reasons i love this site.
LINCOLN ELECTRIC POWER MIC WELDER SETUP (A67714)
LINCOLN ELECTRIC...
2019 Kubota RTV-X900 4x4 Diesel Utility Cart (A66734)
2019 Kubota...
Pallet of Golf Cart Tires (A64912)
Pallet of Golf...
2015 PETERBILT 567 TANDEM AXLE DAY CAB (A66091)
2015 PETERBILT 567...
2022 John Deere Z345 (A64912)
2022 John Deere...
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
