PTO driven seeder/spreader
/ PTO driven seeder/spreader #1
crown
Platinum Member
Winchester, VA
Kubota B-7500
I currently have an Agri-Fab tow behind spreader that I used prior to the B-7500. How much would I expect to pay for a spreader, and what size would I need for my tractor and property size. I guess I can still use the Agri-Fab, but I would like to have the PTO driven type. Any comments and type and experiences are appreciated.
/ PTO driven seeder/spreader #2
Crown,
Do a search for seeder, make sure you click on all posts. You will find two recent threads there, one is seeder or spreeder for my bx2200 and spreeder implements? Anyway there is two good threads there that should give you lots of information. I personally like the Herd Seeder M96 three point. I have about two acres and two neighbors that use it also. It doesn't do the best with the chemical fertilizers but works great on the straight fertilizers. I have used it also for spreeding grass seed. Look at www.herdseeder.com.
Paid about $350.00 with freight and is fairly light so you can move it around
murph
/ PTO driven seeder/spreader #3
<font color="blue"> It doesn't do the best with the <font color="red"> chemical </font> fertilizers but works great on the <font color="red"> straight </font> fertilizers. </font>
/forums/images/graemlins/confused.gif
/ PTO driven seeder/spreader #4
Hi crown--Here is a good selection of various seeder/spreaders with pictures and prices. Check them out for reference. Ken Sweet field maintainence
/ PTO driven seeder/spreader #5
Mike,
You got me on that one. What I meant was is the fertlizers that have the weed killers in it such as Scott's does not work the best because it is more powderised.
Hope that clears it up.
murph
/ PTO driven seeder/spreader #7
Tractor Supply is running a sale on their fertilizer spreader in Texas.
May not be in your area now, but keep an eye out for the flyer.
/ PTO driven seeder/spreader #8
Murph, that's what I thought you meant but wanted to be sure. The stuff that's powdery tends to bridge inside the hopper and then stops coming out, right?
/ PTO driven seeder/spreader #9
Mike,
Not actually, it runs through pretty good but the problem is the spread pattern drops down to about 7 feet. The stuff is so light. Also if windy it does tend to blow. I will use that fertilizer but you just want to make sure that there is no wind, set the 3 point as low as you can and you will have to make more passes with it. Also and this is true with any spreader you will find that fertilizer will tend to blow more out one side of the spreader. I usually set the spreader for about half of what you want the then make two passes. One way then perpendicular on the second.
Hope this helps.
murph
/ PTO driven seeder/spreader #10
Got be careful not to use the weed eating stuff with new growth, or new seeds... you'll kill it fast. That is direct for the Scotts rep who chatted with me at Lowes last spring.
/ PTO driven seeder/spreader #11
me too...maybe he means <font color="blue"> staight </font> from the horse's a**??
/ PTO driven seeder/spreader #12
Murph,
I was trying to find a 3pt spreader that could spread a narrow (6'-10') path. Are you suggesting that if I use the Scotts powder fert in the herd that its easily enough controled that i could consistently work narrow areas?
Thanks,
Buzst
/ PTO driven seeder/spreader #13
Buzst,
You can actually control any type of fertilizer in pretty much any of the PTO driven spreeders by lowering your 3 point and slowing down your PTO/RPM's. If you want to use the Scott's type brands for 6 to 8 feet I think it will work fine by doing both options above. I have used the Scott's brand stuff before and found it to already have a smaller pattern because of it's fine granuals and light weight. I used mine to spreed grass seed and I only got about a 10 foot pattern with it at normal RPM's. Also remember that with any spreeder like this you will tend to also blow more product to one side or the other depending on the rotation of the blade.
murph
/ PTO driven seeder/spreader #15
I did not get the 18" extension. I have two acres and I basically have to go back and refill once. If I had the extension I probably would still have to go back once to fill. If you have a larger area than maybe it would be worth it. I did not get the cover either.
murph
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
2026 Kearney 7'x20' Trailer (A64119)
2026 Kearney...
John Deere 410D Backhoe (A62679)
John Deere 410D...
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
2015 Caterpillar 308E (A64126)
2015 Caterpillar...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
