PTO Driven Badger Roller Mill
/ PTO Driven Badger Roller Mill #1
BrokeFarmerJohn
Columbus Ohio
2017 Mahindra 5555, John Blue G-1000, Massey Ferguson 98, John Deere GP
Hey guys,
I found a PTO driven badger Roller mill on CL and can't find much info on it. I'm gonna go look at it tomorrow. I do not have a model # or any info on the grinder, all I know is the grinder is in good working order and has a 10ft discharge auger off the back.
I plan to use it to crack corn for cattle so it won't see tons of use per year but the ones I have found so far (not badger brand) are 4-5k but those grind and mix.
The guy has a tractor to demonstrate that the grinder works as it should, my only concern would be finding parts.
Let me know if your familiar with one and what you think one is worth. It's been stored in a shed since this guy has had it.
Thanks for any help and advice.
John
I bought it. It needs a few patches and I will take it to a welder then I'm gonna sand blast it and repaint it, the discharge auger also needs a little work (someone extended the discharge cover and it's rotting thin metal which needs replaced.
First thing I did was pull off the wheels and put some used tires I had laying around.
The Roller mill just BARELY fit in the barn door lol 8ft 1in door and the unload auger is 10ft lol fully pitched to the left side it cleared by inches.
It's a 36in roller mill
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
Chandler PT Stainless Steel Spreader (A64126)
Chandler PT...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
EZ-GO Electric Golf Cart (A64127)
EZ-GO Electric...
2018 RAM 2500 (A65643)
Angle Broom (A64126)
