Backhoe PTO Backhoe Conversion? Please Help.
   / PTO Backhoe Conversion? Please Help. #1
waggy5
New York
Kubota M7040 & B2320
Hi, I have a 3 pt hitch backhoe that runs off the PTO and would like to convert it to run off my tractor remotes. Has anybody done this? If so, how? thanks!!!
   / PTO Backhoe Conversion? Please Help. #2
What size tractor do you have? Tapping into the tractor's system isn't hard to do, and there's usually enough pressure available, but if the internal hydraulic pump doesn't put out enough volume the backhoe may move slow.
   / PTO Backhoe Conversion? Please Help. #3
Exactly just like rbargeron posted. A pto pump will most likely put out more volume than the tractor hydrualics ever will. Result will be a slow and powerless back hoe.
   / PTO Backhoe Conversion? Please Help. #4
Just to add something: The PTO pump may let you operate the hoe at idle or very low RPM while using the tractors hydraulics almost always requires a higher RPM.
But, we really need to know what you have before anybody can make a informed suggestion.
Why do you want to make the conversion anyway?
2026 Quality steel dump truck (A56859)
2026 Quality steel...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
Pickup Truck (A59230)
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
